Old 02-04-2010, 04:27 PM
spiritG spiritG is offline
Default Save Copy Assertion "Could not 14405"
"Could not 14405 because Assertion in"/Volumes/Development/vb_protools_8.0_cpr_2/AlturaPorts/PT4_App/MacBuild/../PtSess/PtSess_XChg.cpp", line 1471.
Someone posted this in the LE forum.
Get the same error on a G5 dua 2.5 PCI-x 6gig ram booted off an firewire external 10.5.5 drive running PTHD 8.0 (no cs's) and a Mac Pro running the same off it's internal boot drive. Both finish the error description with "line 1466".
Also tried a macbook pro2.2 with 10.4.(9 or 11) PtLE7.3.1 mbox micro got the same error except line 1269.
All machines frequently have databases and volumes deleted, preferences restored, permissions repaired (a 10+ minute process on the G5).
How can this be fixed?
(PT 8 seems prone to "assertion" errors)
Need Save Copy function to make new folder with only this session's audio files to fit on a DVD- the audio files folder contains lots of files that are from other sessions that shared the same original live show files).
Thanks.
Old 02-04-2010, 05:29 PM
zodo zodo is offline
Default Re: Save Copy Assertion "Could not 14405"
I had this problem once a while back, and fixed it (I think) by doing one of these two things:
*Toggling the copy fades checkbox to be the opposite of what it was
*Rendering out the elastic audio in the session
Obviously, try the first one first.
PT's 10 Crashes when performing "Save Copy In" function soundguy69 macOS 2 07-07-2015 10:01 PM
PT10 : Volume automation disabled after "Save copy In" brenny Pro Tools 10 2 06-18-2015 02:33 AM
"Save copy in..." function copies files that have been cleared from session. ragbor Pro Tools TDM Systems (Mac) 7 02-08-2010 12:25 PM
"save session copy in" audio file name shortening simonchase Pro Tools TDM Systems (Mac) 2 05-10-2002 04:39 AM
"Save Session Copy" MUST copy AIIFF files??? BHeller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-11-2001 12:33 AM
