Old 03-28-2009, 10:34 PM
gould gould is offline
Default have a save question for ya
is it ok, to save on the fly, when things are moving, i do it all the time, but wondering if im gonna make it crash as some point.. i use 6.4.1 pro tools mix with mac dual 1.25 1.5gigs or ram. thanks gould
Old 03-28-2009, 11:28 PM
Howardk Howardk is offline
Default Re: have a save question for ya
Not really different than autosave, so you should not experience any specific problems from saving on the fly. . . But it is somewhat pointless if you are in the middle of a recording pass. . . you may as well wait until after the pass. There is always less change of irregular behavior if your system is not working hard when saving. The advantage of autosave is you have multiple version of the session file, so if something goes wrong, or you make a bad decision, you can back track. . . I typically set mine to 50 copies and 5 minute intervals. . .
Old 03-29-2009, 09:57 AM
pmklein pmklein is offline
Saving on the fly can be a life saver. I do it all the time and have never had a crash, even when recording.
Old 03-29-2009, 11:33 AM
MASTERLINKSTUDIOS MASTERLINKSTUDIOS is offline
But just because you press save while recording the region or regions that are being recorded can't be saved until you stop transport so saving after the record pass is much more efficient in my opinion
Macpro 2.88-4 Gig Ram,HD2,Big Ben,Rosetta 200,Dangerous D Box,Mercury Bundle + Studio classics bundle ,C/24,2-UA 6176,U87ai,Genelec 8050 & 8020,Logic,Final Cut Studio 2,Canon hxa1(hd camera)-Macbook Pro,Mbox 2 Micro.http://www.masterlinkstudios.com/.http://www.myspace.com/masterlinkstudios
Old 03-29-2009, 11:50 AM
crizdee's Avatar
crizdee crizdee is offline
Yes, and worth noting that autosave doesn't happen when the transport is in motion, or editing is being done! it waits till its stopped then saves, so if you're recording an hour show it will only save at the end of the hour recording!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-29-2009, 03:24 PM
only at the end, so theres no way to save it , im doing an audiobook, each chapter goes about 20 min, sometimes he goes with no mistakes. like to think , i could save it somehow without having to stop. Hmmm,
save copy in...Question. angelo panetta Pro Tools 11 6 05-01-2013 04:27 PM
Save copy in as 7-9 question Vedat Pro Tools 10 14 02-02-2012 04:48 PM
Pro Tools 7.3 Save Question??? jaaypeso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-28-2007 01:43 PM
Save As question. 100below Pro Tools M-Powered (Win) 0 06-25-2005 08:23 PM
Question about where to save audio... rossscarbro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-27-2005 11:39 PM
