Old 03-22-2009, 05:47 PM
gould gould is offline
Default boy , i do have a problem, transfer , help
Hello, i have pro tools mix 6.4.1 my client wants the files in wav files. so he can transport to sonar. .. is there anyway to export these files to wav files. Ive looked everywhere in pro tools to find it. thanks gould
Old 03-22-2009, 05:54 PM
TommyT TommyT is offline
Default Re: boy , i do have a problem, transfer , help
If i remember correctly Save session copy as & when the dialog box comes up select all files & select wave Format...
Old 03-22-2009, 06:22 PM
i didnt see anything in for saving wav file in save as, did you have 6.4.1 thanks
Old 03-22-2009, 06:42 PM
anyone else
Old 03-22-2009, 07:32 PM
audiobob's Avatar
audiobob audiobob is offline
This is the only way I know how to do this but others may chime in.
First, if you have multiple edits on all tracks, select all audio on all tracks and hit option-shift-3. That will consolidate all regions into into one region on each track.
Second, again select all audio on all tracks and hit command-shift-k. That will "export selected as files". Choose a destination, .wav and other settings. That will create complete .wav files to import.
Old 03-22-2009, 08:23 PM
elicious elicious is offline
hey gould, like tommy said it's "save session copy"
(just under save as...)
also, like bob says, make sure all trax start at zero ( by consolidating) so there's no time stamp issues.
b.o.l.
e
ihatetyping
Old 03-22-2009, 09:00 PM
hey you guys, THANKS ALOT, IT WORKED, what i did was select all then did command shift k. didnt have any edits, so didnt have to consolidate. all the tracks started a 1 min, hope he can line them up
mac --> pc transfer problem caralarum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-11-2006 04:02 PM
Anyone had this PC to MAC Transfer problem? bassist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-16-2004 05:01 AM
Mac to XP transfer problem.... bassist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 09-19-2003 03:15 PM
transfer problem! Simon666 General Discussion 8 09-16-2003 06:17 AM
Track Transfer won't transfer (time code problem) apetrocelli Pro Tools TDM Systems (Mac) 4 10-17-2000 01:49 AM
