PT8 crashing after save...
I have been using PT8 recently with absolutely no errors or problems. My sessions have 48 tracks, video and plenty of plugins. Everything runs perfect in the sessions, but after saving, closing that session and then seeing the grey PT background....It freezes....eventually giving the WinXP "not responding" error. Then I have to go into taskmanager and end task. very annoying. Oh, and the session actually saves fine. Any ideas? I have done every PT tweak here as well as every other WinXP tweak in existence (really). I've been neck deep in Windows since 3.1 (sadly)
Intel Core2 Duo 2.13 GHZ 3gb RAM Mbox1! |
Re: PT8 crashing after save...
Try removing your plugins from the DAE folder
to Plugins (unused) folder and then try to re-open the session. If the session opens, you may have an outdated or dare I say "Not properly authorized" plugin. If so, Quit PT and drag back your digi plugins back into your DAE folder and leave 3rd party out for now. Lauch PT and the session again. just repeat the steps until the session won't open again and you may find your culprit. Just An Idea. Also try trashing DAE Pref. Folder and Your Digidesign databases. I'm sure more info that you give would help get you a solution. |
I already tried that using the tech support utility. hmmm very annoying!
(-50) ERROR on Save / Auto Save | oldrake | macOS | 1 | 10-14-2013 03:30 PM |
PT10 crashing during "Save Copy In" to PT7-9 | reichman | Post - Surround - Video | 4 | 10-08-2012 07:04 PM |
PT10 crashing during "Save Copy In" to PT7-9 | reichman | Post - Surround - Video | 0 | 10-01-2012 08:48 PM |
crashing on save | woof | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-19-2010 02:18 PM |
7.4.2 crashing on Save As | nukepicnic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-07-2008 11:23 AM |
