Old 07-24-2020, 11:21 AM
Default Re: Kontakt crashing when loading instruments
Originally Posted by noiseboyuk View Post
I'm hazarding a guess here - you don't work in broadcast television, do you?
Nope
Recording keeps me busy enough I don't have to do post work.
Old 07-14-2021, 04:24 AM
Schottlandru Schottlandru is offline
I THINK I FOUND IT!
I can always produce a crash in the following conditions:
1. iZotope RX6 or RX7 Connect AudioSuite window is open
2. Kontakt 5 or 6 window is open
3. Load any library nki in Kontakt - CRASH.
Loading a kit in Battery 4 also crashes, but I haven't found any other instruments from NI or anyone else that misbehave. There might be other plugins besides RX Connect that causes the crash, but haven't found any yet, including other plugins from the RX suite.
Have reported it back to NI tech support, the case has been going on for many months. A huge breakthrough I think and hope. It explains why its routine for me and almost no-one else, RX Connect window is nearly always open for me on any rig, but that's a me thing!
EDIT - just to add, I tested on Mac and its fine, this is a Windows-only bug.
THANK YOU SO MUCH for reporting this. Was bitten by this this week and couldn't figure out what was causing it.
Fantastic to know the workaround.
CHEERS!
Andrew
Old 12-13-2021, 07:45 PM
ReynaldoPena ReynaldoPena is offline
Mine still crashing, I even deactivated NEXUS
Take care brush your hair,
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
iMac (Retina 5K. 27-Inch, 2020)
Processor 3.6 GHz 10-Core Intel Core i9
3.6 GHz Dual-Intel Core i7
16GB ram
AMD Radeon Pro 5700 8GB
Shure SM7B Mic
Pro Tools | Carbon
Komplete Kontrol M32
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 12-14-2021, 04:28 AM
What would Nexus have to do with Kontakt crashing? No problems here with the latest Kontakt.
BTW Kontakt 6 is NOT yet compatible with Monterey.
Old 12-14-2021, 05:42 AM
Yes I wondered why that was in this thread. But it did prompt me to see if they ever fixed the bug of this thread, 2 years later.
Answer - no. At least K5 still crashes with RX Connect 9 open in Windows. K6 (latest version) also still crashes, but not on every patch - was fine on the first one I tried, crashed on the 2nd one. Guess all parties involved just passed the buck and no-one did anything.
Well it hasn't been a problem for me in the past 2 years because I always close RX Connect before loading anything in Kontakt. That workaround is 100% successful.
FWIW I do have Nexus 3 so just tried that - behaving normally here.
Guy Rowland
www.guyrowland.co.uk
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 12-14-2021, 05:45 AM
Are you really needing what's going on in RX that much? In well recorded audio you shouldn't need it.
As a TV dubbing mixer, I still get a kick out of this question all these years later.
Guy Rowland
HTML code is On
Pro Tools 2018.12 crashing when loading Vienna Instruments plugin at startup SuperKons Pro Tools 2018 7 04-22-2019 05:02 PM
Kontakt loading slow in PT 11 mingojr Pro Tools 11 18 03-30-2015 05:19 AM
Kontakt 5 not loading user pre sets keith l Pro Tools 9 0 03-10-2014 07:50 PM
PT 7.0 crashes when loading Kontakt - help! mbatstan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-01-2005 02:44 PM
PB : access violation when loading .gig in kontakt saltine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-14-2004 11:23 AM
