PT9 sample rate problem when loading sessions
Hi. My first post, so please go easy!! (I just crossed over from Sonar after 15 or so years!! )
Missed this in my signature, but running in Windows 7 Ultimate, 64bit Since installing PT, I have a problem in that whatever my MOTU clock is showing as sample rate, if I try to open a session in a different sample rate, it gives me an error message like could not complete the open session..command because while translating Audio Engine settings. When I close PT, and then re-open the file, it opens as normal. What I notice, at this point, is that as I close PT, the MOTU 896mk3 clock LED indicator changes to that session sample rate. When I open it again, of course the MOTU is set accordingly. This happens every timen I switch between a 44.1, 48, 96k session. I know some might say ONLY useone sample rate, and stick to it, but is that correct, or is there a potential fix? It seems that the MOTU might have something to do with this, but I cannot figure what. I have tried setting the MOTU to force Word Out, as well as use the System Clock. ALSO (new topic, one file that was recorded in 96KHz sends a scaringly loud high frequency signal to my ouputes. I have all I/O set for my MOTU but cannot seem to stop this, it is JUST this particular session that it happens with, and it was originally recorded in a PT HD system (Apple). Any thoughts? Thanks so much in advance, Mick. (PS. The last issue was fixed by PT Tech support (for free).... but I cannot contact them now without paying for a new case credit. I did try to pull my case details by email, but it shows nothing.... PLEASE don'tmake me go back to Cakewalk!! )
Pro Tools 2020 Mac Mojave Mac Pro (canister type) Twin Xeon processors 64GB DRAM Apollo Quad + satellite Multiple Enterprise class SSDs (mixed use endurance) Solid State Logic Nucleus. |
Bit Depth & sample rate with sessions & Bouncing.. | bigsmokeproductions | Pro Tools 10 | 17 | 03-06-2013 08:08 PM |
Problem Opening Sessions in Pro Tools 9: Sample Rate Sync Issue. | anthonymunoz | macOS | 0 | 10-23-2011 08:49 PM |
HD I/O digital output sample rate different than sessions? | jasenj1 | Tips & Tricks | 3 | 07-14-2011 07:30 PM |
Bit Rate/Sample Rate problem? The chipmunks? | bspro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-17-2008 05:40 PM |
Sample Rate Standards (what's in YOUR sessions?) | Philthy | Pro Tools TDM Systems (Mac) | 0 | 07-19-2002 04:03 AM |
