Disable Automation Per Channel
Hi
I understand I can turn 'off' automation on a per channel basis but I'd like to 'option' click the whole session into touch but disable specific channels. I could group all the 'active' tracks but is there a more elegant solution? Many Thanks Ben |
Re: Disable Automation Per Channel
You could Option+click any track name to select them all, then Command+click the ones you'd like to leave as is, then Shift+Option+click auto mode on any selected track.
Does that help?
Yea, and welcome to the community :)
Hi Stig
Thanks for the quick reply but I was hoping for a simpler method. There are tracks I would never want to automate, such as layback tracks and auxes to limit stem tracks. It would be great not to have to manually select a range of tracks. Just disable all automation on those and be able to globally put everything else into touch. I did look into disabling automation types on those tracks, is there a way to disable automation types on selected tracks? I can only seem to disable on a per channel basis or globally. Many Thanks Ben Last edited by AudioUproarBen; 10-04-2017 at 09:09 AM. |
Sorry, I'm not aware of a different method. But, why is it a problem to put all tracks into auto touch (or latch) mode? Only the tracks and parameters you change will be written.
Hi Stig
Thanks for your reply, Its just that I won't ever want to write automation to those channels accidentally. All the best Ben |
I understand.
All the best.
You can automation safe individual channels if you want to keep them at the current state.
Save early and often! (or once a day whether you need to or not...) |
Thanks, trakbytes.
Create a group where only automation mode is linked And nothing else.
Then you can change modes including switch off from one fader or change individually by clicking on its name in the group window. |
PT10.3.10 Waves Automation Disable on PT12.5 | modulo2008 | Pro Tools 12 | 0 | 05-09-2016 09:05 AM |
Enable/disable automation playlists | Audioartist | macOS | 6 | 01-27-2016 10:00 PM |
Automation for Plugins on one channel | Ophir_Lokay | Tips & Tricks | 4 | 05-29-2013 11:43 AM |
Deleted plug in automation on the whole channel - WHY??? - please help! | lynx lynx | macOS | 5 | 04-18-2013 02:30 PM |
Is there a way to disable Mute Automation | corym | Post - Surround - Video | 7 | 09-10-2009 10:12 PM |
