Old 05-23-2000, 03:01 PM
link link is offline
Default Waves Plugins only showing up in AudioSuite???
All,
I have a problem! After happilly buying and installing the NPP1 Waves bundle, Imate Griffin and all, I have the Waves Plugins only showing up in AudioSuite!! NOT IN RTAS!!
Any one dealt with this??
HELP!!
Old 05-23-2000, 03:33 PM
Default Re: Waves Plugins only showing up in AudioSuite???
PROBLEM SOLVED!!
I can't believe I did this one all by myself!
For any one that may have this problem in the future, just delete the following files:
System\preferences\DAE:
Plugin Params
Installed plugins
System\preferences\PTLE:
Pro Tools LE 5 preferences
System\preferences\Waves:
C1 preferences
L1 preferences
Qn(10s) preferences
Waveshell-RTAS preferences
then restart ProTools, wait for about 2-3 minutes, and voila!!
You get another chance to say "don't ask me again",
and it works. Both Audiosuite and RTAS are available!
[This message has been edited by link (edited May 23, 2000).]
Old 05-24-2000, 09:57 AM
bentley bentley is offline
hey link,
I'm still having trouble with waves. Can you tell me what machine/speed/os, etc you are
using.Also, did you download the latest imate driver from the griffin website?
Old 05-24-2000, 10:50 AM
lwilliam lwilliam is offline
Most of the problems with Waves are because of the dongle and the iMate. I also believe it's related to USB - since you're doing a USB to ADB conversion.
I had continous problems with the iMate being intermittent and having to constantly trash the prefs to get it to work (sometimes having to trash 2 or 3 times) until I used the "fiddler" app that you can download from Griffin. Try lengthening the "timeout" parameter (the lower one of the two parameters) to give the signal more time to be recognized by the hardware.
I'm using the 1.9 driver and have my timeout set to 30 (whatever units it is) and it now works every time. I believe by default the timeout is set to 15. Just nudge it up a few units at a time until it starts working. Mine works reliably in the range of 27-35, hence I have it at 30.
OS 9.0.4 also seemed to help with USB issues, but I had it working fine with OS9. I didn't have the fiddler app when I was running 8.6, so I don't know if it will work with that.
Also, the iMate seemed to be intermittent on two different USB hubs that I tried, but I've heard of some people having success with a USB hub and the iMate/dongle. I now have it plugged into the 2nd keyboard USB port. Even with a 3' USB extender on the keyboard, it works 100% now.
LW
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 05-24-2000, 01:12 PM
Bentley,
My dongle has actually worked 100% from the start. I am using the 1.9 Imate driver downloaded from
http://www.griffintechnology.com
My setup is G4, 450mhz, 256mb Ram, 28gig extra audio HD, Belkin 4-port USB...OS 9.02
IWilliam,
where are those 'fiddler' timeout settings you reffered to? And did you use that application instead of 1.9 or in addition to it? I've never had an issue with the USB/Imate dongle stuff, but in case I do, I want to know where to look for a solution.
link
[This message has been edited by link (edited May 24, 2000).]
Old 05-24-2000, 01:42 PM
I'm using 1.9 driver which has two user-adjustable parameters. Those parameters can be adjusted by the fiddler program. I don't have it in front of me, but what you do is run the fiddler app against the driver file. It "permanently" sets the parameters in the actual driver file that you use.
The parameters are adjusted with two sliders. The "timeout" or "timing" parameter is the lower of the two. Once you've set it, you just run the driver as normal.
I did this at the recommendation of the Griffen tech support manager. It totally solved the reliability problem for me.
LW
Larry
Old 05-24-2000, 02:24 PM
Thanks, LWilliam!
Old 05-24-2000, 04:35 PM
Sean Halley Sean Halley is offline
BTW, if you ever need to get back into the Waves dialog without trashing pref's, hold down the space bar during startup....
Sean H
"it's not about making the changes, it's about playing ideas in time"
Scofield...
Old 05-27-2000, 07:44 PM
obseco obseco is offline
Just be carefull...
If you try to install another individual plugin the Waves installer will delete your Waveshell RTAS to put a new Waveshell TDM (inside plugins folder)!
Just keep that piece of cake in a safe place...
Waves plugins resetting, and presets not showing logocomic Pro Tools 10 9 01-29-2015 10:29 AM
waves plugins not showing up in inserts snarky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-08-2012 02:53 PM
No waves plugins showing??? Raoul23 Windows 5 05-16-2011 02:15 PM
Waves Plugins Not Showing Up FrankLP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-27-2008 02:01 PM
waves not showing up in audiosuite menu PhiDelta308 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-31-2004 01:09 PM
