Pro Tools 8LE Install Disks are bad
First off, I apologize for putting this Pro Tools 8 thread here, but I did not see a specific forum just for 8.
I am a PC/Network Tech for a school district. A teacher needed help installing Pro Tools 8LE on both Windows and Mac machines. The install discs are brand new, however, all machines fail to recognize the disks at all. I have used 3 separate copies of the discs, all brand new, still in the shrink wrap. The installer disk AND the "audio loops and sounds" disk fails on every machine we have tried it on. Is this a known issue? Was there a bad batch released? Is it possible to get either replacements disks or a link to download the installer for both Windows and Mac? Also, is there a way to download the audio loops and sounds as well? Thanks for your help. |
Re: Pro Tools 8LE Install Disks are bad
Yes, there were tons of bad LE8 disks. Once you register the software, you can access a download for it. Kind of curious and worried that you are wanting to install version 8 when 10/11 are the current versions, and depending on the OS, LE8 may not work on your computers(and LE MUST be used with one of a handful of Digidesign/Avid interfaces, including Mbox 2nd gen, Mbox 3rd gen, 002 and 003). Original Mbox(light blue with Focusrite preamps) only works with LE8.0.1, which means Windows XP(not Win7, 8) and I'm not sure which version of OSX.
what he said ^^^^^^^^^
Thank you for your response. In answer to your questions:
"Kind of curious and worried that you are wanting to install version 8 when 10/11 are the current versions": I'm just the tech. Version 8 is the version that is owned, and unfortunately, there are no plans to upgrade. I assume there is no money budgeted for doing so, nor will there be for a while. From what I understand, though, all the equipment in the classroom should work for this version, but again, I am just the messenger, not the teacher. We'll see once we get this working. I am now having an issue, when trying to activate the product to my account. I get to the page where it asks me to enter the activation code. The code I have on one of the disk cases begins with DIGI. It is DIGIxxxx xxxxxxxx xxxxxxxx, where x is an alphanumeric digit (looks to be hexadecimal). When I enter it I get a message stating the code is not valid. I have made sure to enter the proper case, and I have tried with the spaces, without the spaces and with a- substituted for the spaces. Still no worky.... |
Should be Digi08 something or other
You might want to contact support if you can ASC code - b/c if you have several disks to register it might be easier. I assume that these disks are new? And they haven't been registered before. It may also make u to talk to avid if they were purchased bulk and via edu discounts
Just got off the phone with Avid tech support. They will be sending me the install files.
Beautiful......don't forget to install the creative collection instruments as well as any bomb factory packs that came with your purchases.....
ask avid if your unsure.
And, the authorization code would be "DIGI08...." where the DIGI part is caps, but all other letters are lower case(and the spaces must be included). So, any 0 would be the number zero.
I understand you are just the messenger, but the version of OS on these computers can make or break whether they will work.
Lost serial/registration numbers and install disks. Need help | Dillonc | Getting Started | 8 | 06-14-2013 05:31 AM |
New Win7 Install - Internal hard disks removable? | Jeff_C | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-14-2010 01:17 PM |
WTB OS 10.3.4 install disks for Dual 1G G4 | JNS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-21-2006 09:20 AM |
FIXED!!! HELP NEEDED!!! Need to work! Install disks freeze computer...WHAT TO DO??? | betsy | Pro Tools TDM Systems (Mac) | 40 | 07-31-2003 02:54 PM |
Bad SCII install disks | Hume | General Discussion | 1 | 08-29-1999 11:24 PM |
