Old 07-15-2003, 01:37 AM
gabadilla gabadilla is offline
Default Can you help me w/ mixing this heavy rock band?
I spent the weekend recording a good Heavy Rock / Metal band. The sound they desired was "heavy" without being muddy. I'm used to recording more rock bands who like the brightness and sheen of the songs they hear on the radio. I believe they play tuned down to a C. I guess I can only describe it as very thick.
Does anyone have any experience they can share in this area?
Any pointers or techniques which might help me out?
I'm particulary concerned about this muddiness issue... Do you know what frequencies I should beware of to avoid it becoming a muddy mess?
Thanks!
-gabe
Old 07-15-2003, 01:05 PM
saw saw is offline
Default Re: Can you help me w/ mixing this heavy rock band?
muddiness usually is around 200-300 Hz
Punch In Audio Services
www.punchin.nl
Studio Engineering | Live Engineering | Location Recording | Composing
Old 07-15-2003, 01:07 PM
jamlaw jamlaw is offline
beware of adding too much 60 - 80 to the bass and guitars. things tend to get too muddy if you add lows to everything. Generally I will add a lot of 60 to the kick but cut some from the bass / guitars and vox. I add higher frequency lows gtrs and bass.
DECONSTRUCT ON MP3.COM
Old 07-15-2003, 01:50 PM
mjames08 mjames08 is offline
send me a copy of the session...
Old 07-15-2003, 02:02 PM
Barhab Barhab is offline
I recommend applying a low cut at 120 hz on just about everything except the bass and kick. This should open things up!
Old 07-15-2003, 02:08 PM
The muddiness can by anywhere between 200 and 500 hz - try to set the frequency-gain very high, while you're looking for the problem frequency by running the mouse (or fader) slowly from 200-500 hz. That way you will notice it, when you're passing it!
Old 07-16-2003, 12:38 AM
powerjoe powerjoe is offline
bump
Joel DuBay
Ready Acoustics LLC
Bass Traps and Acoustic Panels
www.readyacoustics.com
Old 07-16-2003, 02:48 PM
Jorge442 Jorge442 is offline
do they want to sound like the new METALLICA????
[img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img]
what a long, strange trip it´s been
www.abacomusic.com
Help Selecting A Guitar Amp for Modern Heavy Rock wolfman_rob Pro Tools TDM Systems (Mac) 26 07-01-2008 09:39 AM
Any suggestions for mixing a Heavy Rock Band? gabadilla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-16-2003 03:50 AM
Here comes that rock band!!! Help! The Fez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-21-2003 09:45 AM
Heavy Metal Hard Rock Bass music Tips & Tricks 3 10-04-2002 06:59 PM
4-pc rock band recording blake eat world 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-14-2001 10:55 PM
