Initializing hard drive questions
I have a 60 gig OWC firewire drive that I run PT sessions on and it has some damaged files. It keeps crashing my system while I run other functions without it on just fine. I ran Disk Warrior and Norton but it doesn't really fix it right (at all). Soooo, I've backed up all my sessions to disc and I want to reinitialize the drive. I can't seem to find the proper method searching the DUC. Can anyone help with a suggestion or link. I have "drive setup" and "hard disk toolkit" or do I just use the "erase disk" on my menu? I can't remember how to do this properly. Thanks... [img]images/icons/cool.gif[/img]
Machine: G5 1.8Ghz RAM: 1.25 Gigs OS: Panther 10.3.2 Pro Tools: LE 6.2.2 Interface: MBox Monitors: Event PS 6 Oxygen 8 Event PS 6 Monitors |
Re: Initializing hard drive questions
Sorry for the double post....I figured it out using a different search criteria......nevermind!
Boot from a system cd if you need to initialize the main system drive or.., go into applications\utilities\drive set-up, select the drive you want and then from the menu select initialize,If you are using 0s9 that is.
Simple as that.
A Gentleman is one who can play the bagpipes, yet chooses not to. |
Highlight your Fw drive on the desktop, and from the special menu, select erase disc.
Hope this is helpful. |
G5 + hard drive questions | GSM79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-02-2004 04:11 AM |
*HARD DRIVE QUESTIONS!* | instro001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 08-17-2004 02:07 AM |
hard drive questions....again | nightshadecrisis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-12-2004 10:38 PM |
Hard Drive Questions | blameus_product | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-06-2003 05:11 PM |
Hard drive questions | Niklas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-30-2002 03:33 AM |
