Old 09-18-2002, 11:54 AM
guisquil guisquil is offline
Default Mbox, Logic 5.3 Direct I|O recording behind 1 beat?
After recording in Logic 5.3 an audio track using the Direct I/O driver, the recorded audio is not in sync with the rest of the tracks, it prints and plays about one beat behind?
If I use the ASIO driver from Steinberg It works fine, but I get no way to control Mbox latency in Logic?
Setup:
PB G3 (FireWire), 384 RAM, Mbox Rev20,
Old 09-18-2002, 05:19 PM
supaheef supaheef is offline
Default Re: Mbox, Logic 5.3 Direct I|O recording behind 1 beat?
hi,
i'm considering a setup not disimilar to yours, as you can pick up a pismo for less than a used ibook. what sort of latency (approx) are you getting with the steinberg asio driver? are you able to play vsti's in realtime?
you should check out the propagamma asio driver, as this has the potential to give low latencies, and control over buffer settings. you have to pay for it, but some have had great results. get the demo at www.usb-audio.com
iBook 600, 640mb RAM, and a big smile on my face...
Old 09-18-2002, 05:27 PM
Kickin.da.speaker Kickin.da.speaker is offline
I suggest my forum, http://f23.parsimony.net/forum49865/ , for further help.
In Logic, in Audio>Audio Hardware and Drivers, under Direct i/o, you shoud have a buffer setting. That's what controls the latency.
David.
6am eternal
Old 09-18-2002, 08:09 PM
Me again, what I meant was "it prints and plays about one beat ahead" if I record an audio count with my voice counting "one, two, etc", when I play it back the audio count starts with two, so you hear two, three, four corresponding to the one, two, three of Logic Internal Click..... I hope I'm making sence
Old 09-20-2002, 06:42 AM
PGrealy PGrealy is offline
Hi
I too have eaxctly the same problem as you in logic.
I have the Programma asio driver and there is not a problem with the delay but there is much faffing around with switching to the asio driver (rebooting the Mac). I have tried everything to get the Direct I/O driver to work but to no avail.
Conclusion : Mbox used with Logic is a waste of time. ( I am sad to say)
PFG
Old 09-20-2002, 02:52 PM
I bought the Propagamma ASIO Driver, and now I'm getting a lot better results
Old 09-21-2002, 01:35 AM
captain54 captain54 is offline
same problem here too...large delay when
recording audio...so Direct i/o and Logic is a total bust???
Old 10-18-2002, 07:06 AM
Billy MF T Billy MF T is offline
dang [img]images/icons/frown.gif[/img]
don't have much to offer to this thread I'm afraid but I'm also have the same prob so I just wanted to subscribe [img]images/icons/wink.gif[/img]
Guitar Direct Plug in to Mbox Recording Simba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-15-2010 11:11 PM
direct recording , line 6 or direct box? dannypassenger General Discussion 3 01-12-2005 07:17 PM
Mbox, Logic 5.5, Direct I/O, PTLE ??? How? dleted 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-20-2003 05:21 AM
Recording direct to firewire w/Mbox pongky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-14-2002 07:40 AM
What's the best BASS direct box direct to PT recording dw Tips & Tricks 18 05-13-2000 08:08 PM
