Old 08-31-2015, 11:57 PM
JLiRD808 JLiRD808 is offline
Default Can PT utilize mouse "tiltwheels"? 4-way scrollwheels that go left<->right too?
I see on lots of mice that have "tiltable" scrollwheels that can be pushed side to side. They're used quite a bit in business settings to scroll horizontally in large spreadsheets I think, 4-way scrolling I think it's called.
Is anyone using a mouse with this feature? I know SHIFT+scrollwheel scrolls PT horizontally, but can the tiltwheel be modified to scrub, or perform some other horizontal feature, maybe even free us from using the SHIFT button?
Hope I'm being clear.
Thanks!
Old 09-10-2015, 02:43 PM
khaudio khaudio is offline
Default Re: Can PT utilize mouse "tiltwheels"? 4-way scrollwheels that go left<->right too?
Thanks!
It depends on the mouse. The Apple magic mouse can scroll sideways by swiping sideways. I have tried a few that could tilt the scroll wheel left/right, but PT (perhaps it was OS X) didn't recognize it as a scroll (it just paged up and down). I also tried setting the tilt to a key combo of shift + the scroll wheel, but IIRC, the software driver didn't like that (had to configure in windows- no mac version of the driver, then save to the mouse itself, then reboot to try in PT). Some newer mouses have ARM procs and storage built in, so they retain settings across systems, but it's a toss-up on whether they scroll side-to-side or not. Maybe you'll have better luck than me if you're using windows. I eventually settled on something that was comfortable, but I do miss the side-scrolling without holding shift.
Kyle Hughes
Old 09-10-2015, 03:00 PM
Richard901 Richard901 is offline
If you're using a Mac, SteerMouse might help.
A 30 day trial is available.
http://plentycom.jp/en/steermouse/
Pro Tools 2023.9
Ventura 13.6
Old 09-10-2015, 04:08 PM
Sorry I should have mentioned earlier that I'm in Windows. There's an app called X-Mouse that I'm trying out now, but not having the best luck.
Thanks!
Old 09-11-2015, 03:03 AM
joachim's Avatar
joachim joachim is offline
Logitech G700s , with their Gaming Software Utility : programmed the push scrollwheel left/right to do "Alt PageDown" and "Alt PageUp" (this shortcut is not documented to work with the edit window, but does). Scrolls by page, works super fine.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
audio "slides left" to autofill deleted section oakenhead Pro Tools 10 4 11-29-2013 09:12 PM
"Space" in Edit Window, to the left of Bar 1 ?!? LSNY macOS 1 05-29-2012 07:47 PM
OT - Weirdest "unclaimed items" left in your studio.... silence_of_stone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 05-15-2003 09:43 AM
Faster Dialog Editing "setup tips, mouse,etc. needed" Erinugene Pro Tools TDM Systems (Mac) 17 01-25-2003 12:06 AM
Reverb plugs coming back "LEFT HEAVY" darla Pro Tools TDM Systems (Mac) 3 09-03-2001 02:32 PM
