Old 01-25-2011, 12:03 PM
not2tech not2tech is offline
Default decklink extreme 3D and P T 9
does anyone know if there is a compatibility doc on what compressed video codecs a decklink extreme 3D will play out with a new mac running PT 9 HD
Old 01-25-2011, 12:51 PM
tom_lowe tom_lowe is offline
Default Re: decklink extreme 3D and P T 9
Was there one released for PT8?
Not sure why you'd want this when the Decklink will playout any flavour of QuickTime as long as you have the correct Quicktime Component installed.
Old 01-25-2011, 02:01 PM
thanks tom, I'm not a video guy, what is the Quicktime Component, is it part or QT app or PT app??? sorry about the easy questions.
Old 01-25-2011, 06:37 PM
It's the file that resides in the QuickTime system folder. So if you want to be able to playback Quicktimes encoded with the ProRes CODEC, you'd need the ProRes component installed. Most that you'd need come with Final Cut Pro, but the Avid ones and ProRes playback can be downloaded from the respective companies.
Old 01-25-2011, 08:17 PM
Ray JB Ray JB is offline
This is the official AVID doc..........
http://avid.custkb.com/avid/app/self...p?DocId=354329
from that doc....
Codecs
While Blackmagic Design cards support many video codecs, the following codecs are officially qualified for use with Pro Tools:
H.264
DVC Pro 100*
HDV*
DV25
Apple Pro Res
Old 01-26-2011, 09:58 AM
Thanks guys I got it now
again thank you for the help!
Old 01-26-2011, 11:59 PM
doctorsunshine doctorsunshine is offline
does someone use the 3D capacity of this card ? I'd like to add 3D projection in our dubbing room....
Regards,
Jerome
Old 02-07-2011, 07:27 AM
rbhun rbhun is offline
I'd just guess as long as you output simple side-by-side from the decklink your projector should recognize it (if it accepts SbS).
The BMD 3D is just a dual input card which can accept two streams and then the user stores it. It also has a compliant hdmi 1.4 out, but I dont think any QT file format is handling the frame-packed format of this. SbS, on the other hand, looks to the SW like a normal HD stream and should be okay.
Old 03-05-2011, 01:54 PM
zoing123 zoing123 is offline
Anyone have an issue with some monitors not seeing 24fps material out of Decklink. Sony Bravias see it but samsung does not.
Dick Maitland C.A.S.
Old 03-05-2011, 01:59 PM
Lightbulb Re: decklink extreme 3D and P T 9
Are you working with HD material at 24fps? If so, I think your Samsung is expecting 1080P, not 1080PsF. There is a setting in the DeckLink Preference Pane labeled "Use 1080P not 1080PsF". Enable that setting and let us know if you still cannot see 24fps material out of the DeckLink.
HTML code is On
Decklink HD extreme certified for PT Frank Kruse Post - Surround - Video 28 03-14-2011 08:40 PM
Decklink HD Extreme 3D Chief Technician Post - Surround - Video 10 03-14-2011 12:55 AM
Protools 9 with Decklink Extreme [email protected] Post - Surround - Video 1 01-12-2011 05:23 AM
DeckLink HD Extreme admix Post - Surround - Video 8 07-26-2006 08:51 AM
Decklink Extreme Vidio I/O StefB Post - Surround - Video 2 12-18-2004 10:25 AM
