Decklink HD Extreme 3D
Hello,
Is the Blackmagic Decklink HD Extreme 3D officially qualified for use with Pro Tools v8.0.3cs1 (or later)? If this information is posted somewhere, I cannot find it easily. Thanks for reading!
Re: Decklink HD Extreme 3D
While it is not officially qualified it works largely as expected. One of our clients installed one a couple of weeks ago and while there were some codec issues related to the H264 files being used, the card behaved as expected.
Could you please elaborate on these H264 codec issues? Thank you,
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) Last edited by Chief Technician; 07-06-2010 at 05:54 PM. Reason: quoting |
For some reason, which we didn't have time to get to the bottom of, when PT played the H264 out of the PCI card it would only present the top 1/2 of the frame. Converting these same files to DNX 36 fixed the issue.
I would have liked to have tested with other H264 codec pictures or had the troublesome files reproduced but time was a limiting factor. Ceri |
Any comment AVID? I don't think Blackmagic produces the non-3D version of this card any longer. What am I supposed to do here?
They were still about 4-5 weeks ago (post-NAB) although maybe our supplier still had a good amount of stock - got an Extreme III card here.
In general with Blackmagic stuff, they pretty much use the same drivers. There's a lot of people using 'unsupported' models with no hassle (one of the intensity models i think?) D |
I just found the link that lists the 3D as being blessed with holy water.
https://c.na2.visual.force.com/apex/...1r400000001lab Actually, that link probably won't work, but I found it in the support database, I swear.
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) Last edited by Chief Technician; 07-19-2010 at 02:26 PM. Reason: link won't work |
Are you guys getting good quality picture using this card?
I've got a deckling extreme 3d, and the picture quality playing out to the tv looks like a bad quality mpeg. I tried difrent codec. any advise? Playing picture out fcp or a similar program looks good, but through Protools it tereble. Any help welcolm?
Louis Enslin PT HDX 2 PT Latest 2020 Mac Pro 16 Core 386 GB Ram www.louisenslin.com |
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Not a big difrence at all!
Busy working on project that I used the canopus to capture, So they are normal DV Pal Pics, and the playback to the has all jagged edges ect, not gppd at all!
Decklink HD extreme certified for PT | Frank Kruse | Post - Surround - Video | 28 | 03-14-2011 08:40 PM |
decklink extreme 3D and P T 9 | not2tech | Post - Surround - Video | 16 | 03-14-2011 12:53 AM |
Protools 9 with Decklink Extreme | [email protected] | Post - Surround - Video | 1 | 01-12-2011 05:23 AM |
DeckLink HD Extreme | admix | Post - Surround - Video | 8 | 07-26-2006 08:51 AM |
Decklink Extreme Vidio I/O | StefB | Post - Surround - Video | 2 | 12-18-2004 10:25 AM |
