Which Digi Plugin Installers?
I've seen in the download page of some of Digi plugins as Smack, Revibe etc. that there are installers V8 labelled (7.3.1 - 8). But in the PT8 announce Digi says that the correct installers are those with "7.4.2".
Can anyone clarify this?
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
Re: Which Digi Plugin Installers?
I'll give this a bump!
Rob Burrell aka mixboy |
Chris
Hope this helps. Oliver |
What the announcement says is that the minimum version required is the one listed under the 7.4.2 column on the compatibility grid.
If you're using that version or newer (obviously you should use a newer version when possible..) you'll be good to go. |
Whats up with Digi plug installers? | digidesigner | VENUE Live Sound Systems | 5 | 03-05-2012 04:26 PM |
Where's the AAX plugin installers? | derF | macOS | 13 | 03-03-2012 09:30 AM |
Installation failed message with Digi plugin installers. | BGMusic | Pro Tools 10 | 3 | 02-07-2012 03:14 PM |
Plugin Manufactures please Update your installers! | @ndy | Pro Tools 10 | 4 | 11-05-2011 12:52 PM |
