Old 06-21-2004, 02:54 AM
Ploch Klaus Ploch Klaus is offline
Default Norton 8.02 - be careful with big FW-drives
Everything worked fine on all my disks - some twenty SCSI-drives and two 80GB FW drives. But not with some new drives i bought.
Had a hard time finding this out: i used several LaCie 250 GB drives (at once or single - did not matter). Copying and unsing large amounts of data was no prob at all. Just erasing some hundred files at once (single file erasing did work fine) crashed all my macs. Found out now that Norton File Saver was the problem. After i made Norton inactive it works fine now!!! So be careful!
Old 06-21-2004, 07:12 AM
MikeAP MikeAP is offline
Default Re: Norton 8.02 - be careful with big FW-drives
Its probably a good idea to be careful with Norton at all. Filesaver is attributed to a host of errors. -9073's, slow emptying of the trash, etc. I experienced kernel panics for the 2 days that I had it installed.
On top of that, Norton in general is not an OS X Install friendly app. It places files all over the OS X partition, many of which are invisible. Uninstall (at least in 7) left a lot of these files there.
¡¡¡be careful in 7.3.1 and cs time insert!!! delpinator Pro Tools M-Powered (Mac) 1 03-01-2007 10:10 PM
Beware and be Careful!!!!!!!!!!!!!!!!! tolovpeace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-15-2004 02:53 PM
OT: New email worm...be careful... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 02-01-2004 03:15 PM
rewire is freaking out...Be careful... El CaCa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-05-2003 03:01 PM
Be careful using templates gracepoint 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-19-2001 12:58 AM
