Old 07-20-2021, 05:08 PM
dez811 dez811 is offline
Default Eucon Key Command Guru Needed
Hello all I'm trying to create a macro in eucon that after I highlight a portion of a wave file will add a track, move up, copy, move down, paste then mute and move selection back up. I can do it manually and it works I just can't figure out how to do it in Eucon
the commands are:
First I highlight a selection then
Shift, Command, N Enter This creates a mono track
P Moves selection up
C ; V Copies selection then moves down and pastes selection
Command M. Mutes what was created by previous command
P moves selection up
Old 07-20-2021, 06:17 PM
mattrixx mattrixx is offline
Default Re: Eucon Key Command Guru Needed
The main problem you'll have here, is between the track creation and the following commands. There needs to be a delay whilst the track is being created, but unfortunately, that is not implemented as yet.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 07-20-2021, 06:25 PM
yea I figured that, I thought pause might work but it doesn't
Old 07-21-2021, 12:44 AM
uptheoctave uptheoctave is offline
Soundflow will allow you to do this.
Old 07-21-2021, 04:53 PM
Cheesehead Cheesehead is offline
or Keyboard Maestro.
There should be a wait/pause command in Eucon, we've been asking for a while.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 07-21-2021, 05:03 PM
I definitely don't want to start a subscription, Keyboard Maestro looks ok but Eucon covers 95% of my needs just one or two things I'd like Eucon to do.
Old 07-21-2021, 07:57 PM
EddieJones's Avatar
EddieJones EddieJones is online now
Yes delay is something we have on the cards to add/fix. I'll try and get it int he next release.
OSX guru needed musicman691 General Discussion 4 09-04-2017 01:37 PM
Imported MP3 files run very hot. Guru Needed! tele27 Pro Tools TDM Systems (Mac) 13 09-15-2011 11:29 AM
001- Midi Guru Info needed jbird MIDI 8 04-21-2003 12:09 AM
Help needed from I/O guru's radioface 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-12-2003 12:49 AM
Pro Tools Guru needed in Vancouver B.C. Craig iSPY Pro Tools TDM Systems (Mac) 0 12-18-1999 02:12 PM
