CPU crash when bouncing real-time
Hello!
Everytime I try to real-time bounce a session I immediately get a CPU error (AAE -9173). When I do an offline bounce or just work on a session, I never get any errors. It also occurs when I try to real-time bounce one single audio track, thus it is very unlikely to be a CPU-overload problem. What could be the real problem? And how can I solve this? Kind regards, Jelle |
Re: CPU crash when bouncing real-time
Note to the mods: As this is not a PT12 issue maybe this could be moved elsewheres depending on what PT version the op is using. |
There are threads about this in the PT11 forum. Please search there.
Sorry, I will try to be clearer this time:
I use: Intel i7 4790 CPU @ 3.6GHz 24GB ram Crucial Ballistix Tactical DDR3 1866MHZ Windows 8.1 PT 11.3.0 SSL MadiXtreme 64 (SSL Soundscape WDM/KS drivers) I was able to localize the problem. It only occurs when bouncing a session located on my D: folder. ( That's a Seagate Barracuda Harddisk ST3000DM001, 3TB, 7200 rpm, Serial ATA 600). When I online bounce a session on my C: folder it works fine. Is this enough info? |
bump
Priviledges?
Sorry - should have checked spellig - I meant privileges - as in hard drive permissions?
Spelling wasn't the issue - I didn't know what you meant by the word itself. I don't think that would cause a crash when in real time but not in offline bounce as you'd still be bouncing to the same drive I would think.
PTLE 7.4 - Bouncing is real time only? | Sam C | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-25-2008 07:04 PM |
Not bouncing in real time | DeafSoulStudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-09-2008 04:59 PM |
Bouncing in non-real time | Bonestown | Pro Tools TDM Systems (Mac) | 1 | 04-04-2007 03:54 PM |
Does Bouncing to Disk have to be Real Time? | healer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 27 | 09-13-2003 02:30 PM |
ONLY Real Time Bouncing? BOOOOO! | schoeps | Pro Tools TDM Systems (Mac) | 16 | 02-23-2000 04:46 PM |
