Old 03-13-2013, 01:18 PM
barbara.goddy barbara.goddy is offline
Question Trouble with AUDIO Setup
Hello,
I have a trouble with AUDIO Setup: when I want to configure the speakers that are connected to my Mbox Pro, I can't hear any sound. Even if I work with my MacBook Pro (Mac OS X 10.6.8, 2.53 GHz, 4GB) detached from the audio interface, I have the same problem. Now the Audio MIDI setup closed unexpectedly and this is the part of the report:
Process: Audio MIDI Setup [1090]
Path: /Applications/Utilities/Audio MIDI Setup.app/Contents/MacOS/Audio MIDI Setup
Identifier: com.apple.audio.AudioMIDISetup
Version: 3.0.3 (3.0.3)
Build Info: AudioConsole-870200~2
Code Type: X86-64 (Native)
Parent Process: launchd [137]
Date/Time: 2013-03-13 21:04:25.056 +0100
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 230707 sec
Crashes Since Last Report: 2
Per-App Interval Since Last Report: 14929 sec
Per-App Crashes Since Last Report: 1
Anonymous UUID: 33E46685-C717-426D-A1B1-ACA04756F4CA
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
abort() called
I also don't understand what is the clock source? Now I've chosen the Built-In Output in the pop up menu, because before there was an audio interface I'd used long time ago (probably computer remembered it).
Thank you very much for your help!
Kind regards,
Barbara
Barbara Goddy
Old 03-13-2013, 01:32 PM
dave911's Avatar
dave911 dave911 is offline
Default Re: Trouble with AUDIO Setup
If you are just trying to get playback working you would set the clock to Pro Tools (internal)
To record you would usually set it to your interface.
Might be better to post this with more info on your setup and PT version .
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra
Audio MIDI Setup: Digidesign Audio Drop-down Item Disappears TonyPT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-15-2007 05:43 AM
Trouble With Audio/MIDI Setup in MAC mlr1122 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-27-2005 03:44 PM
Midi Setup Trouble in PT 6.1 , Digi 001!! G-NAUT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-15-2004 05:00 PM
Midi Setup Trouble in PT 6.1 , Digi 001!! G-NAUT MIDI 0 01-14-2004 01:36 PM
MIDI SETUP TROUBLE G-NAUT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-11-2004 06:31 PM
