Midi Controller Problem
I've got my yamaha s90 es hooked up to my 002 with midi cables. I've got a pro tools session with a midi track and an aux track with an instrument plugin on it. I'm getting no midi signal whatsoever. Everything is record enabled. No midi coming through and no sound. Does anyone have any suggestions for me?
Thanks, Shawn |
Re: Midi Controller Problem
You need to set up a midi device in setup, midi, midi studio.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
No offense intended here. Have you patched the midi cables correctly? midi out of the yamaha to midi in of the 002 and vice versa(can't forget those newbies, I've been there myself). Have you enabled midi thru(I think under the EVENTS menu)? Is your midi track set to input from ALL? Once you get a working signal, you may want to set the midi track output to NONE or to an un-used midi channel to avoid double-triggering(your new midi track re-triggering the yamaha while you are recording). You actually can record your midi with a single midi cable(the second cable out of the 002 and back to the yamaha is not needed for recording or triggering sounds on VI's).
I've tried the midi studio setup and my model number isn't in there, so I went ahead and picked a random one. If that won't work, then how do I get my keyboard to show up in the list of model numbers?
Try turning the keyboard on before opening PT.
I don't know if it'a tha same thing, but I'm using a USB keyboard at the moment and that's how I have to do it, if not PT does not "see" the keyboard.
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
MIDI controller problem | ThunderHorse | MIDI | 0 | 08-06-2010 05:25 PM |
Problem with Midi Controller | scottrolfs | MIDI | 0 | 03-08-2008 05:09 PM |
MIDI Controller Problem | SDX | MIDI | 1 | 12-29-2006 10:26 AM |
Problem with Midi Controller | mastermind423 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-04-2006 04:10 PM |
Midi Controller Problem | Wu-Zei | MIDI | 6 | 01-18-2006 10:42 PM |
