Toshiba Laptop suggestions
Hey all....New to this so I am turning to the real pros for help. Have set up a small home studio and got the mbox as well as a new Toshiba Satellite A70. It seemed to satisfy the requirements but i have had problems from day 1. Hours spent on the phone with Toshiba & Digi tech have resulted in nothing changing. During record & play back I get in a minute at the longest and get error 9029 ( audio porcessing conflicting with other cpu tasks ) no matter what I disbale......and its been bare.......I cannot get more...........techs seem to think it could be a chipset issue which Toshiba denies. Fed up. They will take it back but I must purchase an upgrade from them(credit) I want to know if there is a Toshiba product that you guys have had no trouble with other than the Series 1900 which they no longer make. Any input would be very much appreciated. John
Re: Toshiba Laptop suggestions
What are your specs?
Hi John,
I've run an LE studio (sometimes) on a Toshiba laptop and wouldn't really recommend them. Anyway, I've had to disable the wireless networking, sound card, ethernet, and the SD controller card/slot (and add RAM) for best results. I had to also delete a lot of useless software to get it running its best (careful though unless your a power user/tech). Also, its a definate must to have an external hardrive. Furthermore, closely follow Digidesign's setup specifications for running Pro Tools LE on a Windows XP machine. With some tweaking you can get them to work pretty decent though. Len
www.labranville.com |
I've got an a70 and it works fine. I disabled the wirless stuff and uninstalled loads of software. I have the base MS apps and PT and Ableton installed on it. I must confess to not tracking huge sessions in it but I have never had that error. Ableton works fine with if I use the MBox as the sound card (I used it live several times) - if I use the sound card on the motherboard I get a jump or stutter after about 20 minutes.
Thanks guys I just reformatted the hard drive & will try what you suggest.......plase keep suggestions coming if anyone has experience..John
Hey.Thanks for the reply.....Pentium 4, 60 gig drive @ 5400, 512 ram, have tried it with an external drive....(no go) what else would help you help me? Thanks againb. John
i have a Qosmio G15 with no problems, just make sure you delete all the antivirus BS it
comes with, when i first got it it didn't run as fast as i felt it should of then i deleted the antivirus software it fly's now, goodluck
www.klarityrecordingstudios.com |
Mbox on toshiba laptop | Aaronjr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-02-2006 01:33 PM |
TOSHIBA LAPTOP XTREME? | carlos vega | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-14-2005 03:10 PM |
Toshiba Laptop | ifoundthetime | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-12-2005 02:54 PM |
Digi 002 Best Laptop? Toshiba | Scheme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-20-2005 09:32 PM |
Pro Tools on Toshiba laptop | Adam Ross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-17-2003 01:28 PM |
