Old 12-19-2020, 12:15 PM
BScout BScout is offline
Default Loop Playback minimum now 1 second?
The minimum timeline selection used to be 500ms for loopback. Now it appears to be a minimum of 1 second.
Are others seeing this?
It's highly irritating.
Old 12-19-2020, 12:37 PM
Default Re: Loop Playback minimum now 1 second?
Works for me until just a smidge over ~500ms until loop play kicks out. You have to be in slip mode and just over 500ms, if in grid mode at 500ms it does not work. So if thats worked before maybe a slight calculation/rounding error changed things. But it's does not seem as bad as needing 1 sec to work.
Pro Tools 2020.11 on macOS Big Sur, 2019 15" MBP.
Old 12-20-2020, 11:49 AM
rhumphries rhumphries is offline
Yes, 1 second here too. PTU 2020.5.0 Win10
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5
www.TakomaMedia.com
Old 12-21-2020, 10:16 AM
So 1 person sees the same thing as I do and 1 does not.
I'm on Ult 2020.11 with High Sierra.
HDX system (that has made a difference before with transport issues.)
This is sounding like a bug.
Old 12-21-2020, 01:31 PM
Ah not so fast. I gave more details. I see loop playback does not work with a grid at 500ms and but it does with no grid just a little past 500ms. You don't provide any detail on if you are using a grid, at what resolution etc. With no grid and just playing moving the loop end marker thingy how short a loop can you get the loop to play back?
And yes good point on HDX.. I'm native.
Old 12-21-2020, 07:35 PM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
My threshold for Loop Playback is still 500ms
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 12-22-2020, 09:02 AM
It's 1 second threshold on my system of slip/grid/shuffle/spot. I usually run in Timecode mode, but it doesn't seem to change if I switch to Min:Secs, neither does changing the grid duration.
www.TakomaMedia.com
Old 03-07-2022, 07:13 AM
Noemie Noemie is offline
Hi all,
anyone here found a eay to reduce the 500ms threshold ?
Old 03-07-2022, 12:52 PM
Originally Posted by Noemie View Post
Hi all,
What are you trying to do that requires this short of a clip?
Old 03-07-2022, 02:48 PM
Not really anyone's business but the poster.
But a really easy reason is to find a glitch. Scrubbing doesn't always help in finding glitches but playback looping at normal speed does. You tighten the loop until it is only the glitch.
To the poster, no. No way to do it.
Loop Playback in MIDI = Loop Record? saspro Pro Tools 2019 2 04-01-2020 07:06 PM
Never Loop Playback Dibsy Pro Tools 12 8 02-09-2017 09:32 AM
Question about ProTools looping playback in timeline - minimum length required? natez311 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-21-2010 10:13 PM
Loop Record and Loop Playback will not engage? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2008 06:03 PM
