Bit-Rate and Sampling Frequency change of a session???
Hey,
I would like to change the bit-rate from 16 bit to 24 bit and the sampling rate from 44.1 kHz to 48 kHz, since this is recommended when you record a CD. I thought I go woth the CD defaults, but I´m propably wrong . I can re-record the audio material, so what´s left in the sessions is just instrument tracks with some RATS instruments (Battery and Xpand2). Is it possible to change it easily? How do I do that? |
Re: Bit-Rate and Sampling Frequency change of a session???
I'd create a new session @ 24bit/44.1 kHz and then use Import session data. Don't runt 48k sampling rate when the end product is going to CD, you just need to make sample rate conversions from 48k to 44.1k.
I just wanna do engineering... (as opposed to make music :/ ) |
You can also go to the 'Save Copy As' function and change the settings of the session there (the new settings will be in the saved copy).
A
I Love Audio!!! |
ah ok.
I´ll try that, but somebody´s gotta help me out, I once tried saving a copy and some stuff was gone after . I´d like to have it as a copy so I can delete the original without loosing stuff. Now a very important question: Is there any quality loss when I do that??? I mean saving a copy with 24 bit? |
the bits shouldn't make a big difference (it just will be representative of a 16 bit recording) but upsampling just adds samples that are already there to fill in the gaps so it is destructive to the raw data. resampling would be the best way to go but again would be somewhat destructive. rerecording would be ideal!
A
I Love Audio!!! |
If you're creating a session copy in either a different bit depth or sample rate, Protools has to create new files so always copies all audio files. In your current scenario, this is what would happen. After you've done a session copy, it may be worth moving the old session to the trash temporarily and then opening the new one to make sure it has all the audio files it needs. Protools cannot reference audio files in the trash, so this is a way to check, if you're at all worried. |
Excellent advice above. I also agree that recording at 44.1 saves a sample rate conversion(although there are some that feel the conversion can smooth off rough edges). I usually work at 44.1K and always(unless someone else started a project) record at 24 bit for the increased headroom. That allows you to be more relaxed with your record levels(good for avoiding clipping with that singer that has no mic technique). Just remember that a 24 bit file will need to be dithered to 16 bits for burning audio CD's.
Thank you everybody, have big work to do now
Yes, I´ll rerecord the audio files, that´s no problem. But what about the instrument tracks? They shouldn´t have any quality loss at all right? Or do I have to change something there, too? |
They SHOULD be fine as far as I'm aware.
A
I Love Audio!!! |
PT11.n - no option to change sampling rate in "save as" dialog | BCnSTL | Pro Tools 11 | 3 | 03-18-2014 04:23 PM |
Session sampling rate messup, what are my chances? | digidesigner | Pro Tools TDM Systems (Mac) | 2 | 11-02-2011 10:39 PM |
How to Change A Session's Sampling Rate | homegirl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-17-2007 01:29 AM |
Can I change the sample rate of my session? Help! | Allbaldo | Pro Tools TDM Systems (Mac) | 9 | 05-09-2006 01:05 PM |
Sample rate change during session? | JonMitchell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-02-2005 10:47 AM |
