Old 02-28-2022, 01:34 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Default Understanding Video and and AV sync
Dear sound to picture people
I spend a lot of time online answering video/sync type questions, trying to help people.
I am starting to release a series of useful short educational videos on Source Elements YouTube channel under the ”Source Bites: Understanding Video and Audio Video Sync” moniker.
It will take a while to finish the series ( so please be patient, but I am a few in. It will guide you through some useful knowledge in small easy to to digest chunks.
I hope these may be of some use and fill in some knowledge gaps here and there.
Carry on
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 02-28-2022, 03:29 AM
Default Re: Understanding Video and and AV sync
Would be a good chance to explain the confusing PAL/NTSC option when video ref format is set to 1080p24 in the session setup window.
When set to 1080p25 the option is fixed to PAL (and greyed out) but under 1080p24 it can be switched between PAL and NTSC. PT manual says that menu is disregarded when set to HD trilevel video ref formats which would make sense to me as 24P is neither NTSC nor PAL.
But I wonder how that relates to the fixed and variable options. When you switch between then you can see the SYNC HD actually lose lock and speed cal LEDs which then shortly come back after a second. So there is *something* going on. Would be great to get some clarification on what that does.
Thanks!
Frank,
Old 02-28-2022, 04:35 AM
Interesting. I have much work to do on covering the basics at first….
cheers
BAFTA member
IPS member
Old 04-06-2022, 11:12 AM
The next three VIDEO AND A/V SYNC videos are now up on the SOURCE BITES youtube playlist.
If you have never understood the vitally important difference between INTER & INTRA frame video codecs, or wanted to know just how do I speak Codec?, go watch videos 4, 5 & 6.
Could be a very useful 12 minutes in your professional life
https://youtube.com/playlist?list=PL...kGRSuSjE9uwWEi
cheers
BAFTA member
IPS member
HTML code is On
Keeping Laybacks in Sync (delay compensation and Video sync offset) edit machine Pro Tools TDM Systems (Mac) 6 11-15-2010 11:33 AM
New Tutorial Video series: Understanding Pro Tools audiogeekzine General Discussion 0 02-27-2010 10:58 AM
Sync to video RAlvarez VENUE Live Sound Systems 2 09-16-2006 05:24 PM
Understanding SMPTE, Sync, MTC, and Digibeta dcaudio Post - Surround - Video 5 10-03-2005 09:28 PM
Video Sync & consumer video decks binaural General Discussion 2 07-19-2000 08:20 AM
