Changing MIDI tempo
Hi! I want to change the tempo of my whole project from 92.5 to 101.750 . I can change the waveform based audio samples and drum loops from samples to ticks and then polyphonic before going into the elastic properties and altering the tempo.
However i cannot do the same with the MIDI sequences i recorded because where the polyphonic bit should be it says 'read only' and above that 'none'. Please any help greatly appreciated! |
Re: Changing MIDI tempo
Midi is in TICKS mode by default and will follow your tempo change with no effort
Dave is right. Make sure the timebase for all MIDI tracks is set to ticks (not samples) BEFORE altering the tempo, and you should be golden.
Elastic audio is for audio only.
Its because the session is set to manual tempo.
How do i turn this off? Plz be specific to avoid confusion. Much appreciated! |
You take note of the manual tempo > go to the transport window > turn on the Conductor > hit Return to go to the start of the session > show the tempo ruler > press the + sign at the beginning of that ruler > enter the tempo.
You now have a static tempo map.
Need to Change tempo but without changing existing midi data tempo? | Einsteinwannabe | Pro Tools M-Powered (Mac) | 2 | 09-18-2010 06:58 AM |
Changing tempo w/out changing midi performance??? | toddm7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-12-2005 10:35 AM |
midi and tempo changing | dubman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-03-2005 03:57 PM |
changing tempo without changing midi | wizdoom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-20-2004 05:40 AM |
Changing midi tempo | dkrausz | General Discussion | 4 | 11-20-2001 10:38 AM |
