Old 12-29-2015, 03:15 AM
mronline mronline is offline
Default Tips for enhancing vocals
Hi everyone. Genuine plea for help here.
I would like some help editing vocals please. I don't use instruments in any of my clips - it's all about the vocals. At present all i'm doing is:
1) Recording the vocals
2) Normalize
3) Compression
4) EQ 3 7 band
5) Normalise
and the Aux 1 file includes reverb (d verb)
Here is an example of the type of work im involved in and have carried out so far. Any suggestions/tips on how to improve it would be highly appreciated.
pre-editing:
https://clyp.it/bg0a3ro5
post-editing:
https://clyp.it/3gy0uesx
Regards,
MrO
Old 12-29-2015, 05:21 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Tips for enhancing vocals
Hi, welcome to the community.
Drop normalize and do it right
Janne
Old 12-29-2015, 05:57 AM
sw rec sw rec is offline
Agreed. Too many people use normalize as a band aid. Get your levels right to begin with, you don't need to normalize. Especially not twice.
Old 12-29-2015, 08:40 AM
Indeed, I never use Normalize. I do use Clip Gain(assuming you are on PT10 or higher) to adjust levels of the vocal track to even things out so that compression is hit a bit more consistently. On an older version, I would use the Audiosuite GAIN plugin for this. My plugin chain is usually:
EQ III 1 band EQ(set to high-pass between 100-150Hz to suit the voice)
BF76 (set for very gentle compression of peaks)
SMACK! (for more compression and a bit of "character"
EQ III 7-band(only if I need EQ, and I always dip around 350Hz on BGV's)
Pultec EQ1-A (to add a bit of sparkle, usually Waves Puigtech but the lowly Bomb Factory will do the job on a budget)
I also leave insert slot A open(all the above starts at slot B) so that I can insert Melodyne if required(I want Melodyne to work on the original and unprocessed audio).
Old 01-12-2016, 02:22 AM
Thanks for the replies, much appreciated.
I hope this doesn't sound too cheeky but if someone can give me a step by step guide of how to "properly" edit vocals then I would be very grateful.
I will admit I have limited experience (and therefore am no Pro Tools expert) in editing but I am very keen to learn new ways.
Cheers guys.
Also what's the best way to add a really nice, subtle echo?
Old 01-12-2016, 02:41 AM
JFreak's Avatar
Don't overdo it :)
Oh but seriously, pick an echo/delay plugin and pit it on aux track. Then send your vox to that aux and lift the fader until it isn't so subtle anymore, then back off a little.
Massey TD5 is my favourite free delay. It doesn't cost much to open all features so please support the developer if you can. It is a one-man business.
Janne
Enhancing Vocals DonaldM Tips & Tricks 3 01-16-2010 05:57 AM
Help/tips with vocals LongRoad Tips & Tricks 11 06-06-2009 06:40 AM
In your face vocals Tips !!!! jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-13-2006 07:35 PM
vocals tips and techniques Xone Tips & Tricks 7 08-06-2005 03:49 PM
Any tips on blending old vocals with new vocals? Somebody Pro Tools TDM Systems (Mac) 5 06-07-2000 08:38 AM
