Old 03-13-2011, 09:58 AM
SteveH44 SteveH44 is offline
Default Waves v8 install issues on PT v9 HD
It would seem that Waves is back to problems with Waves v8 running as a Mac standard user. Seemed to have been fixed in v7. Problem is Waves v8r4 will run as administrator, but not as standard user. When ProTools launches as user, it gets hung at Waveshell v8 load in. In version v6, they had you creating a shortcut to redirect the path. Those all appear to be in place with this version. I'm guessing a permission issue.
This is a new machine -8 core Intel 2.4G PPC, OSX 10.6.6, ProTools 9,02 HD5.
In the past Wave would ask to direct it to the Waves Plugin folder, when the screen comes up with a blank request window, then the file browers, you direct it to the plugin folder, it simply hangs at that as well.
Anyone run into this yet? Thanks in advance.
Steve H - LAS/FotoKem Engineering
Old 03-13-2011, 10:21 AM
BRH BRH is offline
Default Re: Waves v8 install issues on PT v9 HD
Here is a guess.. go to App/Digidesign/Protools/plugins alias folder and see how many Wave DAE waveshells there are. Should be just one.
Old 03-13-2011, 11:30 AM
Thanks for the reply. I did verify one Waveshell v8 in the plugins folder. As mentioned, it works as admin. We'll beat up Waves in the morning.
HTML code is On
I can't install Waves 8 jemthebullfrog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-29-2011 07:17 AM
Waves install DG2B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-03-2003 10:16 AM
How I got Waves 3.5 To Install finalcut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-03-2002 06:02 PM
HELP with Waves install.... RonH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-20-2002 04:48 PM
Waves NPP Install Jimmy_Vogt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-31-2002 03:32 PM
