SPDIF - How to record with Apogee Mini Me & Mbox 2 Pro
I just picked up a Mini-Me so that I can use its A/D converters, but can't quite make the connection, maybe you can help me.
I'm trying to record bass through the mini-me into the mbox 2 pro via the SPDIF input. I know the mini-me is getting a signal because I can see it on the LED lights and hear it in headphones. However, I can't get a signal in Protools. I researched the mbox manual, which barely mentions SPDIF, so I must be missing something. I did set the clock source to SPDIF, record-enabled a track to SPDIF L in, and nothing comes in! What am I missing? Thank you!
Protools LE 7.3 Mac Pro 2 X 3 GHz Quad-Core Intel Xeon 4 GB RAM OS X 10.4.9 |
Re: SPDIF - How to record with Apogee Mini Me & Mbox 2 Pro
Hi. The same have happened to me. I use a MiniMe with MBox2 and a macBook for field recordings. When I connect the Mbox to the computer via the front USB-jack, these things can happen. When I switch to the next jack (the one closer to the screen) the problems stops
So I suggest that you try to hook up the Mbox from another USB-jack on the computer. |
I realize this thread is way old, but I'm having the exact same problem. I can get the MBox to accept clock input from the S/PDIF source, but no audio.
I'm a novice at PT, so I might have something routed wrong in the I/O section. But for the life of me I can't figure this out. Anyone else experienced this and have a possible solution? |
I've messed around with the I/O mapping extensively, and still no luck. I'm not sure at this point if I'm doing something wrong, or if this is just an issue with the S/PDIF connection between these two devices.
Has anyone else had any experience with this issue? It's bumming me out... |
Apogee Mini Me and MBOX 2 | lucianosprovieri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 11-08-2008 11:29 PM |
A/D Converters - Apogee Mini Me vs. Mbox 2 Pro | rhinostylee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-13-2007 02:06 PM |
mbox 2 mini/spdif | avamark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-15-2006 02:15 AM |
apogee mini-me / mbox | mrevol666 | General Discussion | 0 | 09-19-2003 10:01 PM |
mbox or Apogee Mini-Me? | peneslapepe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-23-2002 09:14 AM |
