Old 06-16-2023, 01:21 PM
atticmike atticmike is offline
Default Pro Tools Installation via Avid Link or manually?
Hello,
I'm setting up a new Pro Tools Studio Installation on a fresh system, the question is, should I use Avid Link to download and install Pro Tools or the manual file download installation, which is more reliable?
Also, should I right click install as an administrator, the setup file?
Old 06-16-2023, 03:09 PM
Default Re: Pro Tools Installation via Avid Link or manually?
It is not installing per-se that is an issue with Avid Link. It still invokes the standard installer, it's more all the stuff about downloading the installers, correctly working out if installed software needs to be updated, etc.
Like many users I have no time for buggy unreliable Avid Link, it's been demonstrated too many times to be buggy. It's sadly just badly done. Uninstall it, you are better off manually managing your system. And that's true for many plugin managers, ... Softube's one is broken on macOS for example, and then you get stuff like Toontrack Product Manager that just seems very well done.
No need to run the install as Admin. You should be an Administrator on the computer. Everything you need to know is documented: e.g. https://avid.secure.force.com/pkb/ar...s-Installation
Old 06-20-2023, 06:35 AM
I gave Avid Link a try and it worked nicely except crashed during the installation of one plugin but it was still installed. I enjoyed that it did it all by itself and actually worked now flawlessly. I guess they improved it greatly.
Old 06-20-2023, 07:11 AM
JoelG's Avatar
JoelG JoelG is offline
I've been using Link to update PT and plugins for the last year or so without issue. I think the first few versions tarnished folks opinion of it.
The only problem I'm having is it says I have 2 products to update, but everything is updated.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Pro Tools Intro doesn't show Avid Link joaoteodosio Getting Started 2 04-11-2023 09:32 AM
Avid Link activation error pro tools intro alriqa Pro Tools 2 03-21-2023 11:05 AM
Avid Link Download Errors for Avid Link 2022.9 and Pro Tools 2022.9 cmhawke Pro Tools 11 03-08-2023 02:45 AM
Avid link pro tools v 12.5.00 fredmarzin Pro Tools 3 07-21-2022 12:00 AM
Avid Link - Pro Tools Feature Requests - Lounge simonchase Pro Tools 2018 4 01-18-2019 04:13 AM
