Old 04-21-2008, 09:03 AM
SteveH44 SteveH44 is offline
Default Intermittant fades v7.4cs3 PPC
Not sure if we're the only one's in the world with this issue, but we've been getting reports from the control rooms, as well as seeing it for myself, that fades are not rendering as selected. Example - define selection of two regions, an end and a beginning, then Apple F, select both as linear fades ( \ / )for in and out, no linking, and randomly it will render curve on one end or another, and sometimes both ends, other times it will render correctly. Seems that when only configuring a separate end for a fade, fade will render correctly.
This does not happen with a complex session, as setting up two or three channels with tones is all that's necessary. I took a quick look at the forum, but didn't see anything resembling this problem, so I'm likely to believe it might be a user problem.
Thanks in advance for any help.
System spec's 2.5g G5 PPC, OSX 10.4.11, PT v7.4cs3, 2.5g DDR, 9 workstations
Steve
LA Studios Inc.
HTML code is On
Protools 8.0.1 intermittant freezes and hangs Phill Barrett Post - Surround - Video 18 10-30-2009 09:04 AM
Odd intermittant distortion when recording tracks Bassline Pro Tools TDM Systems (Mac) 0 05-28-2006 07:42 AM
Intermittant Midi playback problems with ProTools ERXproductions Pro Tools TDM Systems (Mac) 0 10-23-2004 07:27 AM
ProTools 6.4 - INTERMITTANT STUCK NOTES!!! liquitrax Pro Tools TDM Systems (Mac) 0 06-04-2004 05:14 PM
Intermittant System Reboot?!? Jerm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-17-2001 02:11 PM
