Old 08-18-2007, 02:52 PM
rhinostylee rhinostylee is offline
Default SPDIF - How to record with Apogee Mini Me & Mbox 2 Pro
I just picked up a Mini-Me so that I can use its A/D converters, but can't quite make the connection, maybe you can help me.
I'm trying to record bass through the mini-me into the mbox 2 pro via the SPDIF input. I know the mini-me is getting a signal because I can see it on the LED lights and hear it in headphones. However, I can't get a signal in Protools.
I researched the mbox manual, which barely mentions SPDIF, so I must be missing something. I did set the clock source to SPDIF, record-enabled a track to SPDIF L in, and nothing comes in! What am I missing?
Thank you!
Protools LE 7.3
Mac Pro 2 X 3 GHz Quad-Core Intel Xeon
4 GB RAM
OS X 10.4.9
Old 08-19-2007, 07:47 AM
swam swam is offline
Default Re: SPDIF - How to record with Apogee Mini Me & Mbox 2 Pro
Hi. The same have happened to me. I use a MiniMe with MBox2 and a macBook for field recordings. When I connect the Mbox to the computer via the front USB-jack, these things can happen. When I switch to the next jack (the one closer to the screen) the problems stops
So I suggest that you try to hook up the Mbox from another USB-jack on the computer.
Old 03-02-2008, 06:34 PM
explone explone is offline
I realize this thread is way old, but I'm having the exact same problem. I can get the MBox to accept clock input from the S/PDIF source, but no audio.
I'm a novice at PT, so I might have something routed wrong in the I/O section. But for the life of me I can't figure this out. Anyone else experienced this and have a possible solution?
Old 03-04-2008, 08:25 PM
I've messed around with the I/O mapping extensively, and still no luck. I'm not sure at this point if I'm doing something wrong, or if this is just an issue with the S/PDIF connection between these two devices.
Has anyone else had any experience with this issue? It's bumming me out...
Apogee Mini Me and MBOX 2 lucianosprovieri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 11-08-2008 11:29 PM
A/D Converters - Apogee Mini Me vs. Mbox 2 Pro rhinostylee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-13-2007 02:06 PM
mbox 2 mini/spdif avamark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-15-2006 02:15 AM
apogee mini-me / mbox mrevol666 General Discussion 0 09-19-2003 10:01 PM
mbox or Apogee Mini-Me? peneslapepe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-23-2002 09:14 AM
