Re: 2024.3.1 Midi recording delay (Latency??)
Hmm I was just posting about this problem a few days ago:
https://duc.avid.com/showpost.php?p=...2&postcount=48 But I'm on 2024.3.0 and this is happening. It was my understanding this is how it's always been. You hear notes late when you play live (by whatever latency amount is introduced by the session or delay compensation setting), but it prints them exactly when you hit them on the keyboard. |
In my brief perusing of the new features there are a couple changes to the flow of things & some new settings that might need to be set a certain way in different workflow situations. But can't recall at the moment. I think what I read pertains relates more to how the MIDI channels send data to other VI's and how MIDI Thru works. Last edited by take77; 04-15-2024 at 12:37 AM. |
Pro Tools has historically not ADC corrected for plugin audio latency on instrument tracks. It won't add latency "introduced by the delay compensation setting" to an instrument track itself. The latency you hear on an instrument track should be the real signal flow latency through that track to the output. Things get complex if you flow the instrument track into aux/busses etc. where ADC is applied for plugins, but if you want to track with low latency audio you would not do that if there is latency on those paths. You should be looking at what is going on, e.g. the ADC section of the Mix window will give you a good picture of what latencies are and that instrument tracks themselves are not being compensated. There have been no-end of MIDI and audio latency issues, and you may well be running into them, but I suspect you would benefit by trying to recreate what you think is happening in a trivial session. |
i guess i will not be trying the new update 2024.3.1 which is supposed to fix all this. what a mess. |
2024.3.1 is the same.
I had to go back to 2023.12.1 in order to fix that. And the delay is not the audio but in the notes location on the recorded midi track. you can clearly SEE it. I believe it has to do with the midi chain that changed the whole midi channel output selection.. AVID?? Anyone?? Please let us an option to choose the routing of the midi channel as it was before 2024.3
Shefi Mac Studio M2 Ultra 128GB, OS 13.5 |
#16
#17
Lol sorry my bad, I meant the "buffer size" setting. This video from another user illustrates what I and the OP are describing: https://youtu.be/aVhZedAm6Pw?si=w9funeH8XWo1Ju2X (Although I disagree with him that this is what Pro Tools "should" be doing). To reiterate, the problem is that if there *is* latency introduced somehow, then what you hear when you play/record MIDI is not what gets printed. What you hear is delayed notes but what gets printed is non-delayed notes. I did some testing in a trivial session as you suggested, and I admittedly can't actually tell with the buffer size. But it does exist if latency is present, like you say, from plugins in the chain. It becomes a problem in the gray area of just-little-enough latency that we can intuitively self-correct by playing early so that the notes come out on-beat. However much we can do that is how much the notes get printed early. Last edited by gills; 04-16-2024 at 06:07 PM. |
#18
Re: 2024.3.1 Midi recording delay-Me too!
This is really bad! I have the same problem and virtually the same set-up with an M2 Mac Studio, OS 13.6.4, PT 2024.3.1.
MIDI recording is now impossible as it plays back with a quite considerable delay. What on earth is Avid playing at?! This need fixing fast!! |
#19
Using a mic and recording the stick hitting the pad is a brilliant primary benchmark. Also, showing the reprinted audio of the previously recorded MIDI performance is useful to see. Anyone wrestling with PT/MIDI might wanna check the video out. btw, regarding VI latency in general, The 'Virtual Channels' (on UA's Apollo/Console for example) have a much faster audio response time (for 'live' performing/recording any VI), compared with 'live' auditioning/recording a VI through PT itself. While it can't alter how PT behaves it's an enormous improvement in 'feel' for the player. idk if any 'virtual channels' are available within OP's interface. |
#20
Impossible to record midi since the notes end up late if there’s latency in the session. This bug has been coming and going over the years. It’s hard to believe it’s back…. Avid, come on!! This is embarrassing. |
PT 2024.3 NEW issue MIDI LATENCY | strawb | Pro Tools | 84 | Yesterday 01:38 PM |
Delay/Latency When Recording | D. Reck | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-14-2012 05:35 PM |
PT8 and recording latency/delay ? | chrisdee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 01-16-2009 05:13 PM |
Recording Latency Problem with Delay Compensation ON | jacko | Pro Tools TDM Systems (Mac) | 11 | 10-18-2007 01:50 PM |
Latency Delay While Recording | thejewdrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-11-2004 07:31 PM |
