How do turn a click track inti a grid
How would I make a audio click track lock to a grid........tab to transient,,,beat det...? help??
Tim |
Re: How do turn a click track inti a grid
Use tab to transient + shift-tab to transient to select a couple of measures of the audio click.
i.e. start with Measure 1, beat 1 then select through Measure 3 beat 1. Then select "Identify Beat" from the Edit menu. Make sure the data entered is correct then say OK. It will create a tempo setting matching your BPM in the audio click and the grid will line up. Steve |
It's much faster to use Identify Beat on the first bar and then use Beat Detective. Most drum machines won't have a solid click (tempo).
Rail
Click track not lining up to grid.. any thoughts? | ratava911 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-18-2012 05:38 AM |
Turning a recorded click track into a grid? | DeluxeReverb | Pro Tools M-Powered (Win) | 4 | 01-26-2009 03:02 PM |
Turn off accent in Click Track plugin? | tysonjm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-08-2005 02:15 PM |
Click track and grid edit | Ross H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-06-2004 07:49 AM |
click track and Grid mode, help ! | glockopops | Tips & Tricks | 3 | 01-19-2003 09:44 PM |
