Using an ADAT as a converter
Hey all,
I am currently in the planning stages for putting together an LE based studio. Is it possible to use a physical ADAT machine as a A/D and D/A converter? The signal flow would be something like... external pre ----> Adat analog in -------> ADAT light pipe out ------> Digi 002R lightpipe in -----> 002R lightpipe out -----> Adat lightpipe in ------> Adat analog out ------> Mixer. I am guessing the ADAT would need to be loaded up and record enabled to pass signal through etc. Would there be any latency issues to deal with? The reason I am interested in doing it this way is because I would also like to have an ADAT to take with me to live gigs to record and not have to worry about computers. Let me know if there are any flaws in the plan. I am not too familiar with ADATs so let me know if I am assuming they do things they actually dont! |
Re: Using an ADAT as a converter
Gordon in Austin Mac G4 Digital Audio 466MHz MacOS 9.2, 1.25GB RAM, 110GB HD digi 001, PT LE 5.3 |
Thanks for the response. I am glad to hear that I can at least use an ADAT as a A/D converter without having a tape in it! That leaves the other half of the question. Can I use the ADAT as a D/A converter to have 16 outputs and run them all back into a mixer? (the plan is to mix out of the box).
the adat can not be both an a/d and d/a at the same time. just be aware of that. i used an adat for d/a for a long time on my digi001 and it works well.
A/D converter or ADAT | JRainone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 06-27-2003 08:24 AM |
ADAT ad/da Converter for 002/001 | Sessna | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-12-2003 09:56 PM |
adat as converter | gaus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-25-2002 10:42 PM |
ADAT/Analog converter!?? | mica | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-22-2001 09:09 AM |
ADAT converter | Mr. Sinister | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-06-2001 05:22 PM |
