Old 11-30-2011, 09:50 PM
firsty33 firsty33 is offline
Default Drum Overhead Mics
Hello,
I've been dialing in the sound for recording drums for a couple years now, and everything seems to sound great, (to me at least!) however, the only issue I can't seem to work out is my overhead mic situation. Maybe it's because I have a pair of cheap Cad condenser mics, but nonetheless, the end result is a muddy washy overpowering crash cymbal sound. They also overpower my other mics, (the cymbals). I've worked on gating, all types of compression, -20dB pads, and everything else I can think of. I listen to so many albums and ponder how the drums come through so strongly, but the cymbals are nice and full, (not overpowering) in the background.
Does anyone recommend McDSP Analog Channel? Will tape saturation help this situation?
Any help would be greatly appreciated!
Justin Pitlik
Mac Mini OS X 10.8.5
2.3 GHz Intel Core i7
16 GB 1600 MHz DDR3
Pro Tools 10, 003 Rack, NI Maschine
www.youtube.com/firsty33
Old 12-01-2011, 02:11 AM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Default Re: Drum Overhead Mics
Try some Ribbon Mics
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 12-01-2011, 11:10 AM
Describe the room in detail. Maybe its about placement(the best mic in the wrong position will be crap and cheap mics in the right position can do a surprisingly good job). For instance, my neighbor has a kit in a modest sized room(like an average bedroom size) with a ceiling that is acoustic tile and slightly under 8'. He put his overheads in what would be considered a "normal" position, on either side, looking down, and as high as they would go(these are long, thin, inexpensive pencil condensers). Sound was okay at best. I suggested he point the mics up and move them as close to the ceiling as they could be without actually touching the tiles(same principle as a boundary or PZM mic). Sound improved by a giant step. Another friend had a lower ceiling and we pulled the mics away from the kit, put them chest high and out in front about 5 feet away. Again, it made a big improvement. Also had another friend that would often do 3 mics on the kit. 1 in the bass drum and 2 looking over the drummer's shoulders. Sounded pretty stellar
Old 12-01-2011, 12:38 PM
Ben Jenssen's Avatar
My standard approach was always: OHs capturing from the drummers listening point, the whole set, getting it as good as I could, and adding close mics after that. OHs over or byside the drummers head pointing a little to the sides. Cymbals, even hihat just falls into place. Always worked for me. - as a starting point.
Old 12-03-2011, 01:19 AM
chavernac chavernac is offline
Try to get a balanced tone.
"balanced as in": wanna hear as much of the kick, snare, OH, hi hats, toms, etc...
No hi hat that goes TSH TSH TSH and cymbals that go SPLLAAAAAAAAASH with the rest quiete.
If the sound is too harsh, try to change the mic or put them higher to see if the sound has time to dissipate befire it hits de capsule.
http://puremix.net/video/othering/ev...ads-hihat.html
This video should help you out.
Overhead mics? barters81 The Drum Room 27 09-07-2011 01:46 AM
Drum kit overhead Mics KJVMBird 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 30 05-01-2006 04:35 AM
Overhead Mics.... rock15478 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 09-20-2005 03:31 PM
so it all comes down to.....overhead mics nightshadecrisis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 09-23-2003 08:50 AM
Drum Overhead Mics MikeD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-11-2001 12:36 AM
