Sample rate/playback problems with Mbox3
Well I thought all my problems would be over replacing the Dell notebook with an ASUS after the most fustrating 4 weeks of my life but I've still got problems with the Mbox 3 itself. It seems to get confused with the difference between 44.1 & 48K sometimes. All my sessions are 48k and sometimes it plays them SLOW. Even through Windows Media Player or on YouTube, anything that is 48K will be slow.
Sometimes it takes a whole series of reboots and unplugging the Mbox until the problem fixes itself. It's driving me mad. I read of a few posts from last year that suggested that some of the early Mboxes were faulty, is that correct?? The control panel always seem to show the correct sample rate and host control is not disabled. Any help would be most appreciated. Cheers, Joe PT 8.04 ------------------- Software Sandra Computer Model : Asus N53Jq Workgroup : WORKGROUP Host Name : Joe-Asus User : Joe Processor Model : Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz Speed : 1.86GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 8 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : Asus N53Jq BIOS : AMI N53Jq.209 11/05/2010 Bus(es) : PCI PCIe IMB USB Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 8GB DDR3 SO-DIMM Chipset Model : ASUS Core (Clarksfield/Lynnfield) DMI Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Intel Core Mobile (Clarksfield) UnCore Front Side Bus Speed : 2x 2.13GHz (4.26GHz) Total Memory : 8GB DDR3 SO-DIMM Channels : 2 Memory Bus Speed : 2x 665MHz (1.33GHz) Memory Module(s) Memory Module : 06 SSZ3128M8-EDJEF 2GB DDR3 SO-DIMM PC3-10600U DDR3-1332 Memory Module : 06 SSZ3128M8-EDJEF 2GB DDR3 SO-DIMM PC3-10600U DDR3-1332 Memory Module : 06 SSZ3128M8-EDJEF 2GB DDR3 SO-DIMM PC3-10600U DDR3-1332 Memory Module : 06 SSZ3128M8-EDJEF 2GB DDR3 SO-DIMM PC3-10600U DDR3-1332 Video System Video Adapter : NVIDIA GeForce GT 425M (96 SM5.0 1.12GHz, 1GB, PCIe 2.00 x16) Graphics Processor OpenCL Processor : NVIDIA GeForce GT 425M (96SP 2C 1.12GHz, 1GB) Compute Shader Processor : NVIDIA GeForce GT 425M (96SP 1.12GHz, 1GB) Storage Devices WDC WD6400BEVT-80A0RT0 (640.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 596GB (C:) (D:) Seagate ST31000528AS (1TB, SATA300, 3.5", 7200rpm, NCQ) : 932GB (F:) Logical Storage Devices OS (C:) : 149GB (NTFS) @ WDC WD6400BEVT-80A0RT0 (640.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) LaCie (F:) : 932GB (NTFS) @ Seagate ST31000528AS (1TB, SATA300, 3.5", 7200rpm, NCQ) DATA (D:) : 426GB (NTFS) @ WDC WD6400BEVT-80A0RT0 (640.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) Peripherals LPC Hub Controller 1 : ASUS HM55 LPC Interface Controller Audio Device : ASUS P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semiconductor High Definition Audio Audio Device : ASUS 0BEAh Audio Codec : nVidia 0014h Audio Codec : nVidia 0014h Audio Codec : nVidia 0014h Serial Port(s) : 3 Disk Controller : ASUS P55/PM55/3400 4 port SATA AHCI Controller USB Controller 1 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 3 : ASUS FL1000G USB 3.0 Host Controller Printers and Faxes Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : PCL6 Driver for Universal Print (600x600, Colour) Printer : LAN-Fax M8 (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Adobe PDF Converter (4000x4000, Colour) Printer : Samsung ML-2010 Series (600x600, USB, Colour) Network Services Network Adapter : Atheros AR8131 PCI-E Gigabit Ethernet Controller (NDIS 6.20) Network Adapter : Bluetooth Device (Personal Area Network) Wireless Adapter 1 : Atheros AR9285 Wireless Network Adapter (802.11g (ERP), WEP n-bit, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 98% Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 |
Re: Sample rate/playback problems with Mbox3
My apologies, I just reposted this in the Windows section as there doesn't seem to be an easy way to delete my thread here.
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up | finalcut | Windows | 12 | 02-20-2012 04:00 AM |
Playback problems with Mbox3 | algerij | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-10-2012 06:35 PM |
PT 9 sample rate playback/importing problems | metalacer | Pro Tools 9 | 1 | 03-27-2011 05:15 PM |
Playback problems with Mbox3 PT8.04 on W7 x64 | algerij | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-26-2011 09:17 AM |
Sample rate/playback problems with Mbox3 | algerij | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-16-2011 02:42 AM |
