Old 03-30-2007, 06:42 PM
thenewnoise thenewnoise is offline
Default strange problem when clicking on the nudge menu
Hello,
I'm trying to nudge some vocals around in pro tools and whenever I click on he nudge menu to change the parameters, I get a weird popup that says the following:
Assertion in "/Volumes/Development/vb_cliff/AlturaPorts/DFW/MacBuild/../Views/UMenu.MacOS.cpp". line 922
And the only option is to push "ok"
I've tried trashing all prefs, volumes, etc and still no luck..
I'm running 7.3.1cs2 on a Power PC Dual 2.0
OSX 10.5.8
Pro Tools 8.0 HD
MAC PRO Dual 3.2GHz Quad- Core
8 GB RAM
EXTERNAL OWC FIREWIRE 800 Drives
2 x Digi 192 i/o 24 ins 24 outs
Old 03-30-2007, 07:04 PM
Drew Mazurek's Avatar
Default Re: strange problem when clicking on the nudge menu
It's a know issue. It only effects bars and beats. There's a thread somewhere about it. You'll have to make a new session and import tracks to "fix" it. But it will come back as soon as you select bars and beats in the nudge menu.
www.drewmazurek.com
Old 03-31-2007, 02:09 PM
Errr..
OSX 10.5.8
Pro Tools 8.0 HD
8 GB RAM
Old 05-05-2007, 09:24 AM
WStarnes WStarnes is offline
I am still getting that exact same error, ONLY when clicking on the Nudge menu, just as you reported. Mine is the exact error message "Assertion, etc......Line 922" as you mentioned. I only have this bug on one particular session. All others I have worked on recently are fine.
I tried trashing databases, volumes, preferences, and then creating a new Session from scratch, then Imported session data, Still the same error!
Is there any known fix for this?
Wade
Old 05-05-2007, 11:10 AM
25ghosts 25ghosts is offline
double click next to the drop down and enter e.g. 120 manually - now you are using a "fixed" value already "Known" by the drop menu and you can now use the drop menu without the error
It's one of those great BUGS that digi is dragging along each update - also in paid updates
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Old 05-06-2007, 09:25 AM
Great tip! That is a perfect workaround for now, and indeed makes it functionable. Much appreciated!
Sure wish Digidesign would go ahead and fix this. Surely it's just a small thing to fix in a "cs" update and easily doable?
Thanks again,
Wade
Command + clicking a plugin to stick it to the top of the menu crashes Pro Tools... Focuret Pro Tools 10 0 07-22-2013 11:47 AM
Pro Tools 7.4 top menu, when clicking Help.... Squid Vicious 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-12-2008 04:35 PM
LE 7.3.1 Nudge Pull Down Menu !! HELP PLEASE !! davekenny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-04-2007 02:34 PM
Grid/nudge dropdown menu vocalize 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-12-2002 06:47 PM
No nudge popup menu mark linett Pro Tools TDM Systems (Mac) 0 01-18-2000 06:47 PM
