Whats your step by step approach for post sound work?
Just re-starting on an old project and in order to get a bit more structure over my work i was curious to hear how other people approach theirs.
Of course every project is different (this one has a lot of location sound, no adr, probably quite a bit of music and im doing the whole post process by myself), but i still assume most people have somewhat of a step by step approach and it would be really cool to get some examples. |
Re: Whats your step by step approach for post sound work?
I think your question is too wide and vague. Be ing more specific will generate more replies.
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
I would recommend to start from the dialogue editing. This is one of the hardest goals to achieve as you need to be very precise and know how to make it right for the audience. People call it experience. There are no short cuts when it comes to dialogs. A well edited dialogs only sound good as stand alone without any backgrounds or fx.
Don’t use EQ when editing. Concentrate on editing only. Don’t use noise reduction. Leave it for the mix stage (even if its done by you). You can and must use decrackling, spectral removal tools like iZotope RX as AudioSuite. But copy the original unprocessed as well. When you are happy with your dialogs start with a sound design. This is a whole approach as well as you need to know what standard you are working for: cinema (5.1 mix), stereo only, TV (might be 5.1 as well), internet. Think about the foley, sfx and bg’s. Where do you get it from (someone records foley for you) and if you have enough budget to make it right. But before you start: 1. Calibrate your room. 2. Make sure you are running in sync with a picture. This is not obvious at all. Search some topics here on the DUC, how to proceed with it. Good luck!
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
thanks for the tips mgoorevich.
and i guess your right MIKEROPHONICS, ill try to be more specific next time. |
Quantizing Live drums in 7.4. A Step by Step guide. | Ru_C | Pro Tools TDM Systems (Mac) | 19 | 07-29-2011 07:28 AM |
Needing Step by Step Videos - (read more for details). | Wavelabs | Pro Tools M-Powered (Win) | 2 | 04-16-2009 06:53 AM |
Alesis SR16 control of PTLE6 Step-by-step Needed | Violet Sun Electric | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-24-2003 02:14 AM |
.midnam step-by-step install instructions (OSX) | andrej770 | Pro Tools TDM Systems (Mac) | 2 | 09-09-2003 02:13 PM |
How to Make an OS 9, Universal installer disc, from a G4, OS 9 CD; Step by Step! | editor | General Discussion | 2 | 04-21-2001 03:55 AM |
