Old 12-20-2019, 07:57 AM
nedd nedd is offline
Default What happend to the Primary Soft Keys Bar on Dock?
Installed latest Eucon and Avid Control and noticed that when the bottom most left switch (16 soft key switches at the top of the dock) is pressed nothing actually happens on the Control app, where before it would recall 16 primary soft keys to appear at the bottom of the app. It does appear now if in the preferences of the Control app the "Transport/Soft Keys bar: Off" is turned on, but in the previous version that was not necessary. I could not find any documentations about this changes. Is it a bug?
I can see only the lights turning on on the Dock but nothing in the app?
I think that if you have Dock then you don't really need another transport taking extra space in the app, unless you take the tablet/phone and walk away from it but that is where the preferences are handy so you can turn it on, but why would it be now connected with all the "soft keys bar" that we could control on that space and it worked beautifully by pressing that one switch and turning it on or off.
Old 12-20-2019, 08:03 AM
EddieJones's Avatar
Default Re: What happend to the Primary Soft Keys Bar on Dock?
As you discovered the pref turns them on or off giving back more room if not needed, with it on they should work just as before
Sent from my HMA-L29 using Tapatalk
Old 12-20-2019, 08:36 AM
But wasn't before possible to see those soft keys even without turning the prefs for the transport to on? Just by pressing that left bottom switch?
Old 12-20-2019, 08:48 AM
EddieJones's Avatar
The pref is supposed to be on by default so it would behave like before. What platforms are you on for WS and Tablet?
Old 12-21-2019, 01:25 AM
I am on latest Mac OS Mojave and on iPad Pro 10.5” iOS 13.3
Old 12-21-2019, 06:43 AM
Thanks Eddie,
is there a way to downgrade Avid control to the previous version 19.12.0?
Old 12-23-2019, 04:05 AM
Jamieroden Jamieroden is offline
Having this issue also from the version before 2019.12 eucon.
It has also made the dock touch soft keys non operation for non protools software.
Old 12-04-2022, 02:56 PM
Lcepeda Lcepeda is offline
I am still currently experiencing this problem with my avid dock. Although I am using avid control on my iPhone im Not sure if that might be the culprit. Has anyone found. A solution? Avid dock soft keys button light but they wont show in the app. I would really appreciate it if someone can guide me
Soft Keys - System Soft Key Display Mode skilletaudio Avid S4/S6 0 09-25-2019 09:07 AM
Soft Keys on Dock Don't All Work Logichead Avid S1, S3, Dock and Control App 1 06-01-2019 08:41 PM
How to Adress Function Keys >F12 from the S6 (Soft Keys) innenhofstudios Avid S4/S6 3 05-08-2019 06:34 AM
Soft Keys spoons Avid S1, S3, Dock and Control App 13 10-21-2016 07:37 AM
Soft Keys marrap Artist Series 4 11-28-2011 08:17 AM
