Old 07-06-2021, 06:38 AM
Pythagor Pythagor is offline
Default HDX3 on MacPro7,1 power connection
How do you Guys connect power of HDX3 in 7,1? Are you using Belkin AUX power kit with 1-to-3 power splitter? Or 3 separate power cords?
Thanks
Old 07-06-2021, 06:50 AM
arche3's Avatar
arche3 arche3 is offline
Default Re: HDX3 on MacPro7,1 power connection
Look in your HDx box. It comes with a 1 to 3 splitter. But you might need the belkin one depending on slot you start hdx. It's longer. The avid one is very short.
Sent from my SM-G986U using Tapatalk
Old 07-06-2021, 07:49 AM
Hi Arche3,
this is actually what I'm asking about. Should i extend power from power connector for slot 1 and then use supplied splitter or should i connect every card to appropriate slot power connector
thanks
Old 07-06-2021, 08:12 AM
BScout BScout is offline
In either case you don't use 3 separate power cables.
You use one.
If you use the lower slots (near to the graphics cards) you need the Belkin in addition to the Avid power cable (1-to-3).
If you use the upper slots, then you use the power port near the top cards and only need the Avid power cable (1-to-3) and you don't need the Belkin at all.
There isn't even enough power ports on the motherboard to do a 1-1 setup with power for every card slot.
Hardware/sample rate errors on MacPro7,1 LukeHoward Pro Tools HDX & HD Native Systems (Mac) 4 05-09-2020 05:46 PM
more than HDX3... Andi R Pro Tools HDX & HD Native Systems (Mac) 9 07-27-2013 06:59 AM
HDX power connection Logichead Pro Tools HDX & HD Native Systems (Mac) 2 08-21-2012 07:03 PM
Power Connection Question Becharax Pro Tools 9 7 07-21-2011 01:18 PM
Problem with connection of digi002 with Power Mac G5 2.5 amirkali85 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 03-25-2009 08:50 AM
