Trouble with Activation/License [SOLVED]
Hello All.
I'm installing Pro Tools on my iMac for the first time. I'm new to using Apple as a platform so it may just be lost in translation. I purchased Pro Tools form the Avid website and downloaded everything. I've got my iLok activated. But when I try to open Pro Tools it says the license isn't there. iLok's application doesn't show it either. Does anyone know where/how I find my activation code and license information in my Avid account? Thanks in advance. |
Re: Trouble with Activation/License
Here's a few screenshots of what I keep encountering:
Further make sure that your iLok is plugged in all the time. Does your iMac have USB3 ports? If so they have been shown to have issues with iLoks. You need to purchase a powered USB2 hub and plug the iLok into that and the hub into your computer. |
It appears my PT is registered - it says it's Active. I bought it online and had to log in to my Avid account to download it. It also says my iLok is linked. It appears that it's just not downloading the license info on to the iLok. Is this the part you're suggesting is the USB3 issue? That the USB3 may be what's preventing the communication necessary? Cheers. |
Download ILOk License manager if you haven't already and login there, move the PT12 license along with the annual plan if you have one to your ilok and sunc it afterwards, then start PT and see if that helps. PT doesn't download any license to your ilok key, that is done in the ILM
The screenshot of linked ilok has nothing to do with licenses from Ilok.
Welcome to the community.
You deposited your licenses to the iLok account that uses your email address (not the one you are referencing in this thread). Please remove your empty iLok2 from the account referenced in this thread and sync it to your other iLok account, then activate your licenses using iLok License Manager. (You might also want to remove the screenshots and other references to your iLok User Name from this thread.)
linkedin
linkedin
PT12 Activation [SOLVED] | adam79 | Pro Tools 12 | 7 | 05-17-2015 03:56 PM |
PROTOOLSLE - Activation Code [solved] | kyosti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-07-2013 12:37 PM |
[solved] PTLE 9.0 Crossgrade Activation Problem | Push | Pro Tools 9 | 4 | 03-15-2011 04:23 PM |
Trouble Crossgrading from M-Powered (License/Activation Problem) | SWLR | Pro Tools 9 | 4 | 02-13-2011 06:10 AM |
