Hardware Setup Default file path?
Does anyone happen to know:
a) if there is a file somewhere that contains the default hardware I/O settings? b) if so, the exact path of that file? c) if there's a way to save a particular setup as the default hardware I/O setting? If anyone knows the answer to a) or b) then I imagine the answer to c) would be as simple as replacing the old file with the new one. I'm running PT TDM v.6.4ish on OS 10.3.9. Any help would be greatly appreciated. Thanks! |
Re: Hardware Setup Default file path?
While we're waiting for a more definitive response, I'm going to take an educated guess,
A- There is no defualt hardware setup because the first thing you do when starting the program for the first time is to set up the hardware to your particular system. So I'm gussing this would be in the pref file. B- Pref file in the Users>Library>Preference C- However, this would also contain other program related prefs.
Thomas Anthony Natural Sound |
[BUG for years]: PT ignores default output path when opening AAF/OMFs | Frank Kruse | Post - Surround - Video | 2 | 03-21-2013 11:28 AM |
The file name and path is 257 characters | kimballob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-22-2009 07:38 AM |
in what file are the contents hardware setup saved? | D&N | Pro Tools TDM Systems (Mac) | 3 | 09-29-2007 01:56 PM |
Surround default path | ^Tripper^ | Post - Surround - Video | 16 | 12-18-2006 10:07 AM |
Hardware Setup - Default?? | drumbar | Pro Tools TDM Systems (Mac) | 1 | 12-12-2002 01:32 AM |
