Old 07-15-2012, 12:35 PM
Carl Fuehrer's Avatar
Carl Fuehrer Carl Fuehrer is offline
Default Send session messed up
Hello. I have a session that was previously recorded and basic mixed on the same system I have, but by another engineer. I am the final mixer and producer and have started setting up my mix. I am having some issues with preferences I assume. My playline does not scroll with the song and when I do play the Stop button on the Edit screen transport is lit up and the play button flashes. The system preferences should have never of been changed and as I said the session was worked on previously by this engineer on the same gear. How can I fix these issues? Thanks!
Peace,
Carl Fuehrer
Pulsar Audio Lab
Old 07-15-2012, 11:52 PM
Bob L's Avatar
Bob L Bob L is online now
Default Re: Send session messed up
It sounds like the Edit Window Scrolling has changed, and that you've somehow entered Prime For Playback. I find neither of these as Preference options (LE 8.0.5).
Scrolling = Options>Edit Window Scrolling>Page. This menu item can be set as part of a Template. I'm not sure if it "sticks" at the last choice or is restored by opening another session. In any case, the fix is to reselect the behavior you want.
Prime For Playback can be initiated with Ctrl+Spacebar, or Option+Click on the Transport Record button. In my tests on LE 8.0.5, using this shortcut or the click will invoke flashing buttons you describe, but only once. I did not find a Preference to enable or disable this. You may need to research this one further.
Bob
Old 07-16-2012, 01:49 PM
Thanks so much. I will check the settings next time I mix. I really appreciate your help!
Peace,
Carl Fuehrer
Pulsar Audio Lab
N00b question: Send me the session :Rob: 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-27-2009 07:01 AM
Importing Session from HD to LE Start point all messed up drumbar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-23-2007 05:37 PM
How Do I Send a Session to Someone? ReverbMerv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-28-2006 09:48 PM
Ways to send session files? stuie Tips & Tricks 2 10-16-2005 10:31 PM
send PT session on the net fasttraxx Tips & Tricks 2 11-08-2001 11:36 AM
