Segmentation fault and Bus errors
Sorry if this has been covered, but my searches only turned up posts from a year ago and no solutions I could see for my problem. The system is a quad core mac with 8GB RAM running 10.5.8, and PT 8.01 HD. I'm getting repeated crashes with the error messages: :Segmentation fault" in thread "Main Thread", at address 0X0. And also "Bus error" in thread "Main thread" at address 0x0. If anyone could help diagnose this, it would be very much appreciated, it slowing things down considerably. Thanks |
Re: Segmentation fault and Bus errors
Are you using ReWire or Mojo (SDI)?
Yes using rewire, I have a template set up using Plogue Bidule as a VI host
Hi,I've had this a couple of times when trying to open a 7.4 session in an 8.01cs3..spoke to the support guys at digi and they said that these errors are linked to a memory problem that has been fixed in 8.03.He basically said when importing media into sessions Pro Tools doesn't realease the memory used for say importing another session.So you have to import a session,save and then quit the application then relaunch and open your saved file.It does seem to make a difference if you watch the 'Real Memory ' usage in the activity monitor.The Digi guy said the closer the real memory gets to 1.8 Gb the more unstable Pro Tools will get!!Hope that this is of some help.
Mac Pro TrashCan 3.7 Ghz Quad Core AJA Video Op PT 11.3.1 2xHDX S6 32 Fader 32 Gb Ram |
Try not using Plogue Bidule and see if things improved. I recall seeing this same type of error with v7.3.1, and not using ReWire made most occurrences of it disappear.
Is there anything else I can try? tanjerinepost2 - these are sessions created in PT HD 8.01, but I have heard similiar things about imported files from older versions. Thanks for the tip though |
Problem Ask: "segmentation fault main thread address 0x0" | GodwinLee | macOS | 0 | 11-14-2013 08:54 PM |
Main thread segmentation fault. Kill me now! | garret | Post - Surround - Video | 2 | 12-08-2012 08:25 AM |
segmentation fault in thread "main thread",at address 0x0 when import session data | cheney5 | Post - Surround - Video | 2 | 05-24-2012 04:00 AM |
"Segmentation Fault" "Main Thread" Error | IceLitch | macOS | 6 | 08-12-2011 12:14 PM |
Crash on exit - 'Segmentation Fault"?? | PTGuy | Pro Tools TDM Systems (Mac) | 19 | 08-13-2010 01:44 PM |
