Old 10-28-2014, 08:47 PM
Carl Fuehrer's Avatar
Carl Fuehrer Carl Fuehrer is offline
Default PT 8LE Crashing
Hello. I have an 003 running PT 8LE on an old PowerMac G5 quad. I recently moved and previously everything worked perfect. Now when I fire up PT it crashes while loading the plug-in "Revers-DC Removal.dpm" when it's starting up. I've tried removing my ilok's to see if it would bypass the plug-ins while loading and it doesn't help. The error message I get is: "The application Pro Tools LE quit unexpectedly." I would try reinstalling it all but my disc set is in storage in my old studio and I am 1200 miles away so that's not an option. I need to get this up and running ASAP to finish out some client work and to start working on some personal material.
Peace,
Carl Fuehrer
Pulsar Audio Lab
Old 10-29-2014, 12:30 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: PT 8LE Crashing
You could try removing the DC-removal.dpm plugin from the plugins folder... MacHD>Library>Application Support>Digidesign>Plug-Ins. Then see if it boots without that plugin? If you're sure it is that specific plugin causing it not to boot.
Also all the other troubleshooting tips! Like trashing prefs etc, it's all in the troubleshooting thread...
http://duc.avid.com/showthread.php?t=54888
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-29-2014, 02:21 PM
I tried removing the plug-in and clearing the preferences and it still crashes upon loading.
Peace,
Carl Fuehrer
Pulsar Audio Lab
Old 10-29-2014, 02:45 PM
Make sure you are following the exact directions to trash prefs and databases for your version of Pro Tools.
It may be the next plugin that is causing problems. See if you can guess what one that is. Or just remove all plugins from their folder and see if Pro Tools starts. Put them back in batches until you find a faulty one.
Old 10-29-2014, 02:50 PM
And of that does not work do an uninstall (with clean option) and reinstall of Pro Tools.
Pro Tools 8 LE installers are here ... http://secure.digidesign.com/service...rticleId=43353
Old 10-30-2014, 07:53 PM
Thanks for the links. What about the Music Production Toolkit addition?
Peace,
Carl Fuehrer
Pulsar Audio Lab
Old 10-30-2014, 09:47 PM
The individual plugins are still likely available for download, did you try searching?. The rest is just an authorization mumbo jumbo on your iLok right?
Old 10-31-2014, 10:28 AM
Yes I have the "Turbo Charged" bundle ilok with all the Digi/Avid preinstalled licenses.
Peace,
Carl Fuehrer
Pulsar Audio Lab
Old 11-07-2014, 06:35 PM
If I reinstall PTLE8 and the 8.1CS is there a way to preserve my plug-ins? I don't have all my discs with all of my plug-ins and they are the ones I use the most along with some beta ones that I tested and would never be able to get again.
Peace,
Carl Fuehrer
Pulsar Audio Lab
Crashing A lot... Shifted Music macOS 10 03-14-2013 09:50 AM
Pt 8.0.4 mac osx 10.5.8 crashing JORdanDrivE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 11-18-2010 04:19 PM
6.4 crashing my G5? MoritzRock Pro Tools TDM Systems (Mac) 5 08-13-2004 11:00 AM
>> HD3 crashing OS9 Howardk Pro Tools TDM Systems (Mac) 8 09-25-2003 04:10 AM
Help PT crashing Rarefaction 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-01-2002 12:39 AM
