  #31
Old 06-01-2021, 02:11 AM
nacerme's Avatar
nacerme nacerme is offline
Default Re: Borderless Pro Tools for Windows MAIN THREAD
Originally Posted by Prabha View Post
Very Nice work!!
I'm testing v0.3
I'm in windows 10 build 19041 and PT 2021.3.1 using the Line theme.
It works very nice! except two little details:
- The tittle bar AND the menu bar both dissapear if "hide the tittle bar" is pressed.
- Edit and mix windows can not be resized after made borderless.
Thank you so much!!!
It is normal that you cannot resize edit/mix window that doesn’t have borders. Well borders exists because of that, so you can stretch windows from them. Other bugs, i am going to look into them. Thank you
  #32
Old 07-26-2021, 07:24 AM
fabfilter's Avatar
fabfilter fabfilter is offline
Hi audioheads!
Just tested Borderles Pro Tools for Windows v.02 (legacy color scheme) in Pro Tools 2020.5.0. Worked perfectly! I don't get why Avid hasn't implemented such features yet.
Congrats and thanks a lot nacerme. I'll definitely share your post!
  #33
Old 08-05-2021, 10:40 AM
fabfilter's Avatar
Originally Posted by fabfilter View Post
Hi audioheads!
Hey, audioheads!!
I've been using Borderless for a couple of weeks now and did find a couple of issues when using window configurations and hotkeys I've created. I know it's part of the development process so I'd like to keep contributing to it.
See, currently, I use different configurations adjusted to the two screens I work with. The issue occurs when switching between configurations; for instance, I usually switch between configs 2 and 3. That is, between having the edit and mix windows maximized on my bigger screen, respectively. Then, the only way around it – or at least the only one I've been bothered to figure – has been by reverting the borders and maximizing the windows again, which right away seemed too inefficient to do.
Now, the issue with using hotkeys occurs when hiding the menu bar – apparently AutoHotkey is not able to find it anymore . Although that may have to do more with my lack of scripting skills, the hotkeys work fine when the menu bar is shown. FYI, I use hotkeys to access instances in the menu bar that don't already have a shortcut assigned by pro tools (Preferences, Playback Engine, etc.). Interestingly, AutoHotkey can still find Pro Tools when hiding the title bar...
Anyway, I really think the first issue could be addressed in the next version since window configurations are widely used and wildly useful. BTW, now I'm only hiding the title bar. It's not a whole lot of space, yet I'm very pleased to see a couple more tracks shown down on the screen.
Cheers!!
  #34
Old 08-29-2021, 10:41 PM
Fractyl Nektar Fractyl Nektar is offline
OMG! This **** actually changed my life! I hated going from Mac to Windows(School to Home) and how bad Pro Tools looks in Win comparatively to Mac.
Works Beautifully! Absolutely Wonderful!
All I have left to say is:
THANK YOU!
  #35
Old 10-07-2021, 07:39 AM
thejamieedwards thejamieedwards is offline
Hey thanks for making this great tool! Just reporting a visual bug I didn't see mentioned here - when dragging plugins around to other inserts & sends, the yellow box indicating which slot it's being dragged to is incorrect. This changes depending on the window size of Pro Tools. Tested this on 2 different machines.
In both screenshots, I was moving D3 CL down 1 Insert.
Example 1, maximized window, 3440 x 1440
Example 2, non-maximized window, moving the top left D3 CL
  #36
Old 10-22-2021, 04:10 AM
Skwaidu Skwaidu is offline
I assume there is nothing that can modify the plugin window borders for PT 2021?
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3
Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1
HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES.
  #37
Old 11-29-2021, 01:54 AM
I can confirm the above mentioned dragging plugins yellow rectangle bug on Win 11 / PT 2021.10
Also, I found out that when editing Automation Lanes in the Edit, it doesn't show the automation value at all, so I'm not using this for now (the plugin bug I could probably live with, but auto values I need to see). Still interested in any progress made though!
  #38
Old 01-17-2023, 10:11 AM
BCnSTL's Avatar
BCnSTL BCnSTL is offline
Is this still actively supported / developed?
I want to use it but the bug that prevents dragging plug-ins around accurately is a killer. Anyone *not* encountering the bug? Maybe folks running in 1080 resolution?
2023 M2 Pro - MacBook Pro 16 -16GB RAM - 1TB SSD.
2021 Razer 14 Ryzen 9 5900HX - 16GB RAM - 1TB SSD.
PT 2024.3 Native
Life is like an Analogy.
  #39
Old 01-17-2023, 11:00 AM
Suad Cokljat's Avatar
Suad Cokljat Suad Cokljat is offline
Has anyone tried Skootch with recent versions of Pro Tools?
From my side I can confirm it works OK with ProTools HD10 and 12 on Windows 7 x64 PC. It works with various screen setups from single laptop display to 3 x QHD desktop displays. I really cannot imagine ProTools life without Skootch.
Cheers!
Suad
  #40
Old 01-19-2023, 06:24 PM
BCnSTL's Avatar
I paid for Skootch way back-in-the-day but damn if I can find the email exchange with Mr Nagy and he's gone dark.
It seemed to work better than than this free tool but back then I only used 1080 screens.
PT 2024.3 Native
segmentation fault in thread "main thread",at address 0x0 when import session data cheney5 Post - Surround - Video 2 05-24-2012 04:00 AM
Help: Bus Error In thread MAIN THREAD AT ADDRESS 0x0 Icesis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-11-2011 01:09 PM
bus error in thread main thread at address 0xbfffd010 abayman65 Post - Surround - Video 2 01-28-2010 07:17 AM
"Illegal instruction" in thread "Main Thread" LEDGE7 Pro Tools TDM Systems (Mac) 5 11-18-2009 12:50 AM
"Bus Thread" error in "Main Thread" glebestudios Pro Tools TDM Systems (Mac) 17 03-13-2008 04:15 PM
