Old 06-29-2021, 08:11 AM
Matthew Steel Matthew Steel is offline
Default Recording to shared storage in 2021?
What is the current state of recording in Pro Tools in facilities with several rooms/workstations?
1) Record to removable drives and sneakernet them to another system?
2) Record to local storage with a central NAS/server for transfer/archive?
3) Record directly to central NAS/server?
4) Fixed storage per workstation with peer-to-peer network shares? Is it feasible to record to a share on another workstation if the network is fairly local and decent speed?
5) Something else?
I am asking because we use a legacy shared RAID system that will need to be replaced at some time. This system is an iSCSI RAID that has dedicated point-to-point gigabit ethernet connections to two or three workstations. Sharing is managed by Studio Network Solutions SANmp such that any volume can be mounted by any connected workstation, although only one can have write access to a given volume at a time. At the time our current system was put together, this method was just about the only way to record to shared storage since Pro Tools required block level access to disk drives.
Probably our most demanding tracking requirement would be live events lasting several hours and recording 32 tracks or more. Or punching in fewer tracks at a time on sessions that could be significantly larger than that.
Old 06-30-2021, 09:24 AM
Brandonx1 Brandonx1 is offline
Default Re: Recording to shared storage in 2021?
. I switched to a NAS 6 months ago. An Qnap TVS-1288x. 10gbe connection. the ZFS filing system alone makes it worth it.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Protools 11 on shared storage cuttercarlo Pro Tools 11 0 02-02-2016 02:12 PM
Moving sessions and shared storage swpowe macOS 4 11-16-2011 01:15 PM
Shared Storage for PT Editors sleadley Post - Surround - Video 22 01-20-2009 12:45 PM
Shared storage for multiple PT systems kmad Pro Tools TDM Systems (Mac) 14 04-13-2007 08:22 PM
shared storage lafrosty Storage Subsystems 0 03-31-2006 10:50 AM
