Old 07-05-2002, 11:16 PM
Raven Raven is offline
Default Digital noise only on a 24-bit 44.1 kHz session!!
Hi
i am facing a wierd problem at a studio.
Digi001 on Win '98 SE with O2R is giving a digital glitch, only on a 24-bit / 44.1kHz
Tried diff cables, different cards and even a different mixer...initialised and re-installed oS and PT.
The O2R is set to internal and the LE is set to Optical.
The wierd thing is that it is fine at 16 bit.
Any ideas?
Old 07-06-2002, 11:10 AM
Bastiaan Bastiaan is offline
Default Re: Digital noise only on a 24-bit 44.1 kHz session!!
Maybe a rerally dumb question, but is the O2R capable of 24 bit?
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 07-08-2002, 05:01 AM
vonbleak101 vonbleak101 is offline
The O2R is not happy at 24bit, the revision 2 is a little better, but unless you get the 24/96 specific version you are better off sticking to 16bits. [img]images/icons/grin.gif[/img]
Audio Engineer/Musician/Producer
Old 07-14-2002, 10:13 AM
DESDRUMS DESDRUMS is offline
Raven Im using the same setup with no problems or you using the version 2 chip.I was getting digital noise but once I got the word clock correct it stopped. Thats with 24-bit 44.4kHz session.Call Yamaha they have great tech support.
Digital Noise on Mac Pro when opening a session bortraws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-30-2006 01:32 AM
Digital Noise Notefarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-27-2002 10:04 AM
Digital noise only on a 24-bit 44.1 kHz session!! Raven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-08-2002 10:20 PM
Digital noise only on a 24-bit 44.1 kHz session!! Raven Tips & Tricks 0 07-05-2002 11:15 PM
Digital noise opening a session w/oo1 Skaberlakestudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-09-2002 02:01 PM
