Old 07-30-2004, 08:31 PM
vze24x2x vze24x2x is offline
Default Can\'t Cut & Paste Automation Data????
What the hell? Is there something obvious I'm doing wrong? some preference or something?
thanks for any help!
-BK
Old 07-30-2004, 09:58 PM
doug_hti doug_hti is offline
Default Re: Can\'t Cut & Paste Automation Data????
I don't know if you are talking about volume or sends, but if you are talking about sends...i believe that you have to post automation onto the same send from one track to another...so if you are posting auto from track 2 send B, you have to post automation onto another track to send B. There may be a work around in the preferences, but I haven't found it.
If you are wanting to copy VOLUME automation TO a SEND(s). Then you can select that towards the bottom of the EDIT menu.
If you are simply copying VOLUME to VOLUME, then that should work already.
Doug
Old 07-30-2004, 10:52 PM
Steve MacMillan Steve MacMillan is offline
Remember if you are trying to paste dissimilar automation data, you must use "control-command-v".
STeve
macmandigital.com
Old 07-31-2004, 09:57 AM
Thanks for the Reply guys, yes indeed, Control Command Copy is what I needed. thanks.
-BK
copy-paste clip and automation data marcelkavka Pro Tools 10 2 08-13-2012 04:20 AM
copy paste region without data? crizdee Pro Tools TDM Systems (Mac) 4 01-18-2007 04:32 AM
copy plugin data ,paste on another parameter ? andre tchmil Tips & Tricks 2 01-17-2007 10:36 PM
Copy/paste automation data: Volume to Trim Gain?? el biciclista Pro Tools TDM Systems (Mac) 3 11-22-2006 08:50 PM
Converting MIDI volume data to automation data? Duff Studios Pro Tools TDM Systems (Mac) 2 12-17-2002 09:39 AM
